String Ascii to int
pilar
String Ascii to int
PostPosted: Tue Jan 29, 2013 4:50 pm     Reply with quote
Hi, some one can help me...
I have a string ascii:
Buffer[0] = 0x31;
Buffer[1] = 0x31;
Buffer[2] = 0x33;
Buffer[3] = 0x39;
I should I do to get the equivalent: 4409 decimal?, I need this to do math
Mike Walne
PostPosted: Tue Jan 29, 2013 6:14 pm     Reply with quote
There are 'C' functions for this, ATOI(), ATOL(), ATOI32.
Take your pick.
Mike
EDIT Your ASCII values convert to 1139 !
pilar
PostPosted: Tue Jan 29, 2013 6:17 pm     Reply with quote
Embarassed Maybe I misspoke, I'm getting for the Uart the Ascii characters 1,1,3 and 9, representing a hexadecimal number 0x1139, these characters must be equivalent to 4409 in decimal value, my problem is that I have the any idea how to make their equivalence ... :
Mike Walne
PostPosted: Tue Jan 29, 2013 6:30 pm     Reply with quote
To do it by hand:-
1) Convert first digit from HEX to decimal. //1
2) Multiply by 16. // 16
3) Convert second digit to HEX. // 1
4) Add results from 2 and 3 together. // 17
5) Multiply new result by 16. // 272
6) Continue until you run out of digits.
Mike
PostPosted: Tue Jan 29, 2013 7:03 pm     Reply with quote
Here is a 16-bit version of a function that I used to use for this:
#include <18F4520.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=4M)
#include <ctype.h>
// Ascii to unsigned long -
// Converts a string of 1 to 4 ascii hex characters to an
// unsigned long (16-bit) value.
int16 axtoul(char *ptr)
char i, temp;
int16 result;
result = 0;
for(i = 0; i < 4; i++)           // Convert a maximum of 4 hex digits
    temp = toupper(*ptr++);      // Get the char.  Convert to upper case
    if(isxdigit(temp) == FALSE)  // Is ascii char a hex digit ?
       break;         // Break if not
    temp -= '0';      // Convert the char to binary
    if(temp > 9)
       temp -= 7;
    result <<= 4;      // shift existing value left 1 nybble
    result |= temp;    // Then combine it with new nybble
return(result);
int16 result;
int8 buffer[] = "1139";   // Hex value
result = axtoul(buffer);
printf("result = %lu \r", result);
pilar
PostPosted: Tue Jan 29, 2013 7:16 pm     Reply with quote
Very Happy Thank you....
asmboy
PostPosted: Wed Jan 30, 2013 7:39 am     Reply with quote
not to be a nit picker but if it is really a string , i would include
Buffer[4] = 0;
the way you want to handle it, "buffer " does technically NOT contain a "string" at all, unless every instance is limited to 4 bytes by code.
just my 2 cents
