[How To] Create a own USB HID device
benni
PostPosted: Sun Dec 30, 2012 8:12 am     Reply with quote
Hello Community,
A few days ago I started to create my own USB device.
I also saw that much guys tried that also, maybe they got it working or not and because of this I want to release my C# and my PIC Project.
The C# program is not fully made by me, but I edited it and even got it working for my device.
The most important things in the PIC firmware:
Commands:
//Commands
#define CMD_LED2_ON 0x80
#define CMD_STATE_LED2_ON 0x81
Check the incoming data for the Commands:
//Get the Data
usb_get_packet(1,in_data,16);
//Write to the LCD that Data has been received
printf(lcd_putc,"\fReceived Data:\n");
//Check if the incoming byte equals the Command
if(in_data[0] == CMD_STATE_LED2_ON)
  //Write to the LCD that command 0x81 has been executed
  printf(lcd_putc,"LED2 is: %d", input(LED2));
  //Check if LED is high
  if(input(LED2))
     //Set the output byte to 0x01 == true
     out_data[0] = 0x01;
     //Send data
     usb_put_packet(1,out_data,16 USB_DTS_TOGGLE);
     output_high(LED2);
     //set the output byte to 0x00 == false
     out_data[0] = 0x00;
     //Send data
else if(in_data[0] == CMD_LED2_ON)
  //Toggle LED State
  printf(lcd_putc,"Turn LED2 ON");
  output_toggle(LED2);
The most important things in the C# Project
Execute a command:
public void RunCommand(Byte be)
PID and VID:
Int32 myProductID = Convert.ToInt32(0x0042);
Int32 myVendorID = Convert.ToInt32(0x04D8);
Get data from the PIC for example: Read the LED state:
if (!hidHandle.IsInvalid)
    ReadCommand(0x81);
    //Read the LED state
    bool ledState = Convert.ToBoolean(m_Result);
    if (ledState == true) this.ledStateLabel.Text = "LED is on";
    else this.ledStateLabel.Text = "LED is off";
Here are the Downloads, hosted on my server:
Firmware:
Firmware
C# Program
C# Program
Schematic (The LCD is just for Debugging, the Schematic does not contain a schematic how to wire it.
Easy Schematic
Example Picture (You see there much more than it's needed. I use this Board also for an ADC Reader)
Example Picture
I hope it helps to understand it and getting it working for you too and I hope that someone moderator will make it sticky.
Leave a comment please Smile
Regards Benni
rakkoc
PostPosted: Mon Aug 12, 2013 9:31 am     Reply with quote
Links are broken, can you upload again ?
benni
PostPosted: Thu Oct 03, 2013 6:12 am     Reply with quote
Hey,
Links are updated.
Regards Benni
ze.vana
PostPosted: Sat Mar 08, 2014 5:22 am     Reply with quote
benni wrote:
Hey,
Links are updated.
Regards Benni
you are right I'm the one who is having a lot of difficulty starting on usb hid devices
I have started in visual c# 2008 last year, and now c# 2010. I've already made many C# projects
communication with PIC4550,2550 usb->PC, but using C# serial Port, I wanna do it using HID.
But As the guy said "THE LINKS ARE BROKEN". Could you please send me it by email:
ze.vana@hotmail.com , I have an account in www.4shared.com, if you have too, you can put the your links there.
pieter
information
PostPosted: Fri Mar 14, 2014 12:12 am     Reply with quote
Hi Benni, can you please post your downloads on the forum?
Thanks!
sohar
PostPosted: Thu Aug 14, 2014 11:44 pm     Reply with quote
Note: CCS defaults to software i2c, unless you use the
hardware i2c pins and add the FORCE_HW parameter to the #use i2c()
statement.
####### Abdul Rehman ########
