akohlsmith
| [solved] PIC24F32KA304 eeprom_write() addresses off by one? |
Posted: Wed Aug 22, 2012 5:49 pm |
tl;dr version:
| Quote: | | DON'T USE WRITE_EEPROM=noint!! |
I'm using CCS 4.135 and MPLAB 8.84. I'm writing to the on-board EEPROM with the following little test:
/* tried without this line as well, no change */
#DEVICE WRITE_EEPROM=noint
#define EEPROM_LEN (64)
void eeprom_test(void)
static enum { INIT=0, WRITE, READ, ERASE } state = INIT;
static int count=0;
static unsigned int16 pat[EEPROM_LEN];
unsigned int16 w;
bool bad;
int i;
switch (state) {
case INIT:
printf("\r\nNew EEPROM pattern:");
for (i=0; i<EEPROM_LEN; i++) {
pat[i] = 0xaa00 + i;
if ((i % 16) == 0) {
printf("\r\n");
printf("%04x ", pat[i]);
++count;
state = WRITE;
case WRITE:
#if 1
write_eeprom(i*2, pat[i], 2);
#else
write_eeprom(0, &pat[0], sizeof(int16)*EEPROM_LEN);
state = READ;
case READ:
bad = FALSE;
printf("\r\nRead back EEPROM pattern:");
w = read_eeprom(i*2,2);
// read_eeprom(i*2, &w);
// read_eeprom(i*2, &w, 2);
printf("\r\n");
printf("%04x ", w);
if (pat[i] != w) {
printf("!(%04x) ", pat[i]);
bad = TRUE;
if (bad) {
printf("\r\nFAIL\r\n");
} else {
printf("\r\nPASS\r\n");
state = ERASE;
case ERASE:
for (i=0; i<64; i++) {
pat[i] = 0xffff;
state = INIT;
default:
state = INIT;
This routine is called once a second, just for simplicity. That's plenty of time to write 64 words.
You'll also note that I've tried a few different ways to read, and a couple of different ways to write. The method used doesn't seem to matter.
What I notice is that the EEPROM data is written incorrectly. My serial port output looks like this:
| Quote: |
New EEPROM pattern:
a000 a101 a202 a303 a404 a505 a606 a707 a808 a909 aa0a ab0b ac0c ad0d ae0e af0f
b010 b111 b212 b313 b414 b515 b616 b717 b818 b919 ba1a bb1b bc1c bd1d be1e bf1f
c020 c121 c222 c323 c424 c525 c626 c727 c828 c929 ca2a cb2b cc2c cd2d ce2e cf2f
d030 d131 d232 d333 d434 d535 d636 d737 d838 d939 da3a db3b dc3c dd3d de3e df3f
a101 !(a000) a202 !(a101) a303 !(a202) a404 !(a303) a505 !(a404) a606 !(a505) a707 !(a606) a808 !(a707) a909 !(a808) aa0a !(a909) ab0b !(aa0a) ac0c !(ab0b) ad0d !(ac0c) ae0e !(ad0d) af0f !(ae0e) b010 !(af0f)
b111 !(b010) b212 !(b111) b313 !(b212) b414 !(b313) b515 !(b414) b616 !(b515) b717 !(b616) b818 !(b717) b919 !(b818) ba1a !(b919) bb1b !(ba1a) bc1c !(bb1b) bd1d !(bc1c) be1e !(bd1d) bf1f !(be1e) c020 !(bf1f)
c121 !(c020) c222 !(c121) c323 !(c222) c424 !(c323) c525 !(c424) c626 !(c525) c727 !(c626) c828 !(c727) c929 !(c828) ca2a !(c929) cb2b !(ca2a) cc2c !(cb2b) cd2d !(cc2c) ce2e !(cd2d) cf2f !(ce2e) d030 !(cf2f)
d131 !(d030) d232 !(d131) d333 !(d232) d434 !(d333) d535 !(d434) d636 !(d535) d737 !(d636) d838 !(d737) d939 !(d838) da3a !(d939) db3b !(da3a) dc3c !(db3b) dd3d !(dc3c) de3e !(dd3d) df3f !(de3e) df3f
FAIL
So as you can see, my pattern array is correct, and the first word of EEPROM should be 0xa000. If I use MPLAB to read back memory I see the first EEPROM address as 0xa101 (confirming the read is correct):
(picture shows EEPROM window with data starting at address 0x7ffe00: 0xa101 0xa202 0xa303...)
My code is writing to EEPROM location 0, the data it's writing to 0 is 0xa000. I've tried a few different ways to write but the data seems offset by one 16-bit word.
Any ideas?
Update
For those who will complain that my test routine is too long, I wrote a simpler one that shows the same effect:
write_eeprom(0, 0xa000);
write_eeprom(2, 0xa101);
write_eeprom(4, 0xa202);
The memory dump of the first three words is 0xa101 0xa202 0xa202. Note that the first word is skipped, the second word is written to the first word's address, and the third word is duplicated to the second and third locations.
If I change the addresses to 0,1,2 instead of 0,2,4, I get a compiler error sayign odd addresses aren't allowed. This indicates to me that the addresses are byte addresses, not word addresses.
Update 2
If I use just a single write to address 0, I get the data I was expecting at address 0 (0xa000). If I write to address 2 afterward, address 0 gets written as well as address 2. If I write to address 0 and 4, address 0 and 4 get the same value (0xa101) and address 2 gets left alone (0xffff). I'm erasing the device after every test.
Update 3
It was WRITE_EEPROM=noint after all. I must not have re-built after changing it the first time.
Does this qualify as a bug in CCS? |
