PIC24 Address Exception ASM Help!
Tom-H-PIC
PostPosted: Sun Jul 29, 2012 6:40 pm     Reply with quote
Hello All
I need help.
I'm just starting to work with the PIC24.
I have worked with the PIC18 and smaller for the last 10 years.
But the bigger PIC are a whole new animal!
Also I'm not good at ASM at all!
I have learned about exceptions and trapping them but when I get it trapped it does me no good.
I'm working with the PIC24HJ128GP502 and CCS Version 4.135.
This is the data displayed on the debug terminal.
A.F. 0x24D2
D7FF D D801 D7FC 3 D7FF D700 2A
0 0 0 0 0 0 0 1F96
0xF1C=ED8 0xF20=40 0xF1A=ED8
As you can see the problem address is 0x24D2
Here is the list output from that area
.............................. int FindFirst (const char * fileName, unsigned int attr, SearchRec * rec)
0247E 781F85         MOV     W5,[W15++]     : Push W5 to TOS
02480 781F86         MOV     W6,[W15++]     : Push W6 to TOS
02482 781F87         MOV     W7,[W15++]     : Push W7 to TOS
02484 20FF24         MOV     #FF2,W4        : W4 = FF2
02486 888144         MOV     W4,1028        : [1028] = W4
                         ..............................     FSFILE f;
                         ..............................     FILEOBJ fo = &f;
                         ..............................     CETYPE result;
                         ..............................     WORD fHandle;
                         ..............................     BYTE j;
                         ..............................     BYTE Index;
                         ..............................     DEBUG_FS_STR("FindFirst()", 0);
                         ..............................     FSerrno = CE_GOOD;
02488 EF685A         CLR.B   85A            : [85A] = 0
                         ..............................     if( !FormatFileName(fileName, fo->name, 1) )
0248A 2001C0         MOV     #1C,W0         : W0 = 1C
0248C B41028         ADD     1028,W0        : W0 = [1028]+W0
0248E 780280         MOV     W0,W5          : W5 = W0
02490 B3C010         MOV.B   #1,W0L         : W0L = 1
02492 B7F037         MOV.B   W0L,1037       : [1037] = W0L
02494 F80FEC         PUSH    FEC            : PUSH FEC to TOS
02496 F91038         POP     1038           : POP TOS to [1038]
02498 8881D5         MOV     W5,103A        : [103A] = W5
0249A 021396 000000  CALL    1396           :
0249E E00400         CP0.B   W0L            : Status set for W0L - 0
024A0 3A0004         BRA     NZ,24AA        : if W0L!=0 GoTo 24AA
                         ..............................         FSerrno = CE_INVALID_FILENAME;
024A2 B3C120         MOV.B   #12,W0L        : W0L = 12
024A4 B7E85A         MOV.B   W0L,85A        : [85A] = W0L
                         ..............................         return -1;
024A6 EFA000         SETM    0              : W0 = FFFF
024A8 37014C         BRA     2742           : GoTo 2742
                         ..............................     DEBUG_FS_STR("FindFirst()", 2);
                         ..............................     rec->initialized = FALSE;
024AA 2002A0         MOV     #2A,W0         : W0 = 2A
024AC B40FF0         ADD     FF0,W0         : W0 = FF0+W0
024AE 780280         MOV     W0,W5          : W5 = W0
024B0 EB4A80         CLR.B   [W5]           : [W5] = 0
                         ..............................     DEBUG_FS_STR2("FindFirst() start_copy", fileName);
                         ..............................     for (Index = 0; (Index < 12) && (fileName[Index] != 0); Index++)
024B2 EF702D         CLR.B   102D           : [102D] = 0
024B4 808164         MOV     102C,W4        : W4 = [102C]
024B6 DE2248         LSR     W4,#8,W4       : W4 = W4 >> 8
024B8 E1246C         CP.B    W4L,#C         : Status set for W4L - C
024BA 310024         BRA     C,2504         : if W4L>=C GoTo 2504
024BC 808164         MOV     102C,W4        : W4 = [102C]
024BE DE2248         LSR     W4,#8,W4       : W4 = W4 >> 8
024C0 807F63         MOV     FEC,W3         : W3 = FEC
024C2 418004         ADD     W3,W4,W0       : W0 = W3+W4
024C4 200001         MOV     #0,W1          : W1 = 0
024C6 400060         ADD     W0,#0,W0       : W0 = 0+W0
024C8 780280         MOV     W0,W5          : W5 = W0
024CA A0F005         BSET    W5.F           : W5.bit = 1
024CC 2000C1         MOV     #C,W1          : W1 = C
024CE 780105         MOV     W5,W2          : W2 = W5
024D0 090001         REPEAT  #1             : Repeat next instruction (1 + 1) times
024D2 7858B2         MOV.B   [W2++],[W1++]  : [W1++] = [W2++]
024D4 E00006         CP0     W6             : Status set for W6 - 0
024D6 320016         BRA     Z,2504         : if W6=0 GoTo 2504
                         ..............................       DEBUG_FS_STR("FindFirst() 2.5", Index);
                         ..............................         rec->searchname[Index] = fileName[Index];
024D8 808164         MOV     102C,W4        : W4 = [102C]
024DA DE2248         LSR     W4,#8,W4       : W4 = W4 >> 8
024DC 200183         MOV     #18,W3         : W3 = 18
024DE 418004         ADD     W3,W4,W0       : W0 = W3+W4
024E0 807F84         MOV     FF0,W4         : W4 = FF0
024E2 400284         ADD     W0,W4,W5       : W5 = W0+W4
024E4 808164         MOV     102C,W4        : W4 = [102C]
024E6 DE2248         LSR     W4,#8,W4       : W4 = W4 >> 8
024E8 807F63         MOV     FEC,W3         : W3 = FEC
024EA 418004         ADD     W3,W4,W0       : W0 = W3+W4
024EC 200001         MOV     #0,W1          : W1 = 0
024EE 400060         ADD     W0,#0,W0       : W0 = 0+W0
024F0 780300         MOV     W0,W6          : W6 = W0
024F2 A0F006         BSET    W6.F           : W6.bit = 1
024F4 2000E1         MOV     #E,W1          : W1 = E
024F6 780106         MOV     W6,W2          : W2 = W6
024F8 090001         REPEAT  #1             : Repeat next instruction (1 + 1) times
024FA 7858B2         MOV.B   [W2++],[W1++]  : [W1++] = [W2++]
024FC 784A87         MOV.B   W7L,[W5]       : [W5] = W7L
Would you guys look at it and give me some idea of what is going on?
Tom
