| waleed.ahafeez
				| Drivers for KS0713 Family Graphic LCD |
				|  Posted: Fri Apr 20, 2012 12:32 am |   |
				| [/code] 	  | Code: |  	  | ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
 DRIVERS FOR KS0713 Family Graphic LCDs
 Drivers modified by Waleed Bin Abdul Hafeez
 APPLICATION ENGINEER
 HUNCH AUTOMATION LAHORE PAKISTAN
 #byte pa   =0xF80
 #bit dt_cs        =pa.5      // RA5
 #bit dt_rst       =pa.4      // RA4
 #bit dt_sclk      =pa.3      // RA3
 #bit dt_sid       =pa.2      // RA2
 #bit dt_rs        =pa.1      // RA1
 #bit dt_bl        =pa.0      // RA1
 BYTE const TABLE5[48][5]=
 {0x00,0x00,0x00,0x00,0x00,   // 20 space          ASCII table for NOKIA LCD: 96 rows * 5 bytes= 480 bytes
 0x00,0x00,0x5f,0x00,0x00,   // 21 !
 0x00,0x07,0x00,0x07,0x00,   // 22 "
 0x14,0x7f,0x14,0x7f,0x14,   // 23 #
 0x24,0x2a,0x7f,0x2a,0x12,   // 24 $
 0x23,0x13,0x08,0x64,0x62,   // 25 %
 0x36,0x49,0x55,0x22,0x50,   // 26 &
 0x00,0x05,0x03,0x00,0x00,   // 27 '
 0x00,0x1c,0x22,0x41,0x00,   // 28 (
 0x00,0x41,0x22,0x1c,0x00,   // 29 )
 0x14,0x08,0x3e,0x08,0x14,   // 2a *
 0x08,0x08,0x3e,0x08,0x08,   // 2b +
 0x00,0x50,0x30,0x00,0x00,   // 2c ,
 0x08,0x08,0x08,0x08,0x08,   // 2d -
 0x00,0x60,0x60,0x00,0x00,   // 2e .
 0x20,0x10,0x08,0x04,0x02,   // 2f /
 0x3e,0x51,0x49,0x45,0x3e,   // 30 0
 0x00,0x42,0x7f,0x40,0x00,   // 31 1
 0x42,0x61,0x51,0x49,0x46,   // 32 2
 0x21,0x41,0x45,0x4b,0x31,   // 33 3
 0x18,0x14,0x12,0x7f,0x10,   // 34 4
 0x27,0x45,0x45,0x45,0x39,   // 35 5
 0x3c,0x4a,0x49,0x49,0x30,   // 36 6
 0x01,0x71,0x09,0x05,0x03,   // 37 7
 0x36,0x49,0x49,0x49,0x36,   // 38 8
 0x06,0x49,0x49,0x29,0x1e,   // 39 9
 0x00,0x36,0x36,0x00,0x00,   // 3a :
 0x00,0x56,0x36,0x00,0x00,   // 3b ;
 0x08,0x14,0x22,0x41,0x00,   // 3c <
 0x14,0x14,0x14,0x14,0x14,   // 3d =
 0x00,0x41,0x22,0x14,0x08,   // 3e >
 0x02,0x01,0x51,0x09,0x06,   // 3f ?
 0x32,0x49,0x79,0x41,0x3e,   // 40 @
 0x7e,0x11,0x11,0x11,0x7e,   // 41 A
 0x7f,0x49,0x49,0x49,0x36,   // 42 B
 0x3e,0x41,0x41,0x41,0x22,   // 43 C
 0x7f,0x41,0x41,0x22,0x1c,   // 44 D
 0x7f,0x49,0x49,0x49,0x41,   // 45 E
 0x7f,0x09,0x09,0x09,0x01,   // 46 F
 0x3e,0x41,0x49,0x49,0x7a,   // 47 G
 0x7f,0x08,0x08,0x08,0x7f,   // 48 H
 0x00,0x41,0x7f,0x41,0x00,   // 49 I
 0x20,0x40,0x41,0x3f,0x01,   // 4a J
 0x7f,0x08,0x14,0x22,0x41,   // 4b K
 0x7f,0x40,0x40,0x40,0x40,   // 4c L
 0x7f,0x02,0x0c,0x02,0x7f,   // 4d M
 0x7f,0x04,0x08,0x10,0x7f,   // 4e N
 0x3E,0x41,0x41,0x41,0x3E,};   // 4f O
 BYTE const TABLE6[48][5]={
 0x7f,0x09,0x09,0x09,0x06,   // 50 P
 0x3e,0x41,0x51,0x21,0x5e,   // 51 Q
 0x7f,0x09,0x19,0x29,0x46,   // 52 R
 0x46,0x49,0x49,0x49,0x31,   // 53 S
 0x01,0x01,0x7f,0x01,0x01,   // 54 T
 0x3f,0x40,0x40,0x40,0x3f,   // 55 U
 0x1f,0x20,0x40,0x20,0x1f,   // 56 V
 0x3f,0x40,0x38,0x40,0x3f,   // 57 W
 0x63,0x14,0x08,0x14,0x63,   // 58 X
 0x07,0x08,0x70,0x08,0x07,   // 59 Y
 0x61,0x51,0x49,0x45,0x43,   // 5a Z
 0x00,0x7f,0x41,0x41,0x00,   // 5b [
 0x02,0x04,0x08,0x10,0x20,   // 5c
 0x00,0x41,0x41,0x7f,0x00,   // 5d
 0x04,0x02,0x01,0x02,0x04,   // 5e
 0x40,0x40,0x40,0x40,0x40,   // 5f
 0x00,0x01,0x02,0x04,0x00,   // 60
 0x20,0x54,0x54,0x54,0x78,   // 61 a
 0x7f,0x48,0x44,0x44,0x38,   // 62 b
 0x38,0x44,0x44,0x44,0x20,   // 63 c
 0x38,0x44,0x44,0x48,0x7f,   // 64 d
 0x38,0x54,0x54,0x54,0x18,   // 65 e
 0x08,0x7e,0x09,0x01,0x02,   // 66 f
 0x0c,0x52,0x52,0x52,0x3e,   // 67 g
 0x7f,0x08,0x04,0x04,0x78,   // 68 h
 0x00,0x44,0x7d,0x40,0x00,   // 69 i
 0x20,0x40,0x44,0x3d,0x00,   // 6a j
 0x7f,0x10,0x28,0x44,0x00,   // 6b k
 0x00,0x41,0x7f,0x40,0x00,   // 6c l
 0x7c,0x04,0x18,0x04,0x78,   // 6d m
 0x7c,0x08,0x04,0x04,0x78,   // 6e n
 0x38,0x44,0x44,0x44,0x38,   // 6f o
 0x7c,0x14,0x14,0x14,0x08,   // 70 p
 0x08,0x14,0x14,0x18,0x7c,   // 71 q
 0x7c,0x08,0x04,0x04,0x08,   // 72 r
 0x48,0x54,0x54,0x54,0x20,   // 73 s
 0x04,0x3f,0x44,0x40,0x20,   // 74 t
 0x3c,0x40,0x40,0x20,0x7c,   // 75 u
 0x1c,0x20,0x40,0x20,0x1c,   // 76 v
 0x3c,0x40,0x30,0x40,0x3c,   // 77 w
 0x44,0x28,0x10,0x28,0x44,   // 78 x
 0x0c,0x50,0x50,0x50,0x3c,   // 79 y
 0x44,0x64,0x54,0x4c,0x44,   // 7a z
 0x00,0x08,0x36,0x41,0x00,   // 7b
 0x00,0x00,0x7f,0x00,0x00,   // 7c
 0x00,0x41,0x36,0x08,0x00,   // 7d
 0x10,0x08,0x08,0x10,0x08,   // 7e
 0x78,0x46,0x41,0x46,0x78};   // 7f
 BYTE const font_bold1 [48][8]={
 0,   0,   0,   0,   0,   0,   0,   0, //' '
 0,   6,  95,  95,   6,   0,   0,   0, //'!'
 0,   7,   7,   0,   7,   7,   0,   0, //'"'
 20, 127, 127,  20, 127, 127,  20,   0, //'#'
 36,  46, 107, 107,  58,  18,   0,   0, //'$'
 70, 102,  48,  24,  12, 102,  98,   0, //'%'
 48, 122,  79,  93,  55, 122,  72,   0, //'&'
 4,   7,   3,   0,   0,   0,   0,   0, //'''
 0,  28,  62,  99,  65,   0,   0,   0, //'('
 0,  65,  99,  62,  28,   0,   0,   0, //')'
 8,  42,  62,  28,  28,  62,  42,   8, //'*'
 8,   8,  62,  62,   8,   8,   0,   0, //'+'
 0, 128, 224,  96,   0,   0,   0,   0, //','
 8,   8,   8,   8,   8,   8,   0,   0, //'-'
 0,   0,  96,  96,   0,   0,   0,   0, //'.'
 96,  48,  24,  12,   6,   3,   1,   0, //'/'
 62, 127, 113,  89,  77, 127,  62,   0, //'0'
 64,  66, 127, 127,  64,  64,   0,   0, //'1'
 98, 115,  89,  73, 111, 102,   0,   0, //'2'
 34,  99,  73,  73, 127,  54,   0,   0, //'3'
 24,  28,  22,  83, 127, 127,  80,   0, //'4'
 39, 103,  69,  69, 125,  57,   0,   0, //'5'
 60, 126,  75,  73, 121,  48,   0,   0, //'6'
 3,   3, 113, 121,  15,   7,   0,   0, //'7'
 54, 127,  73,  73, 127,  54,   0,   0, //'8'
 6,  79,  73, 105,  63,  30,   0,   0, //'9'
 0,   0, 102, 102,   0,   0,   0,   0, //':'
 0, 128, 230, 102,   0,   0,   0,   0, //';'
 8,  28,  54,  99,  65,   0,   0,   0, //'<'
 36,  36,  36,  36,  36,  36,   0,   0, //'='
 0,  65,  99,  54,  28,   8,   0,   0, //'>'
 2,   3,  81,  89,  15,   6,   0,   0, //'?'
 62, 127,  65,  93,  93,  31,  30,   0, //'@'
 124, 126,  19,  19, 126, 124,   0,   0, //'A'
 65, 127, 127,  73,  73, 127,  54,   0, //'B'
 28,  62,  99,  65,  65,  99,  34,   0, //'C'
 65, 127, 127,  65,  99,  62,  28,   0, //'D'
 65, 127, 127,  73,  93,  65,  99,   0, //'E'
 65, 127, 127,  73,  29,   1,   3,   0, //'F'
 28,  62,  99,  65,  81, 115, 114,   0, //'G'
 127, 127,   8,   8, 127, 127,   0,   0, //'H'
 0,  65, 127, 127,  65,   0,   0,   0, //'I'
 48, 112,  64,  65, 127,  63,   1,   0, //'J'
 65, 127, 127,   8,  28, 119,  99,   0, //'K'
 65, 127, 127,  65,  64,  96, 112,   0, //'L'
 127, 127,  14,  28,  14, 127, 127,   0, //'M'
 127, 127,   6,  12,  24, 127, 127,   0, //'N'
 28,  62,  99,  65,  99,  62,  28,   0, //'O'
 BYTE const font_bold2 [48][8]={
 65, 127, 127,  73,   9,  15,   6,   0, //'P'
 30,  63,  33, 113, 127,  94,   0,   0, //'Q'
 65, 127, 127,   9,  25, 127, 102,   0, //'R'
 38, 111,  77,  89, 115,  50,   0,   0, //'S'
 3,  65, 127, 127,  65,   3,   0,   0, //'T'
 127, 127,  64,  64, 127, 127,   0,   0, //'U'
 31,  63,  96,  96,  63,  31,   0,   0, //'V'
 127, 127,  48,  24,  48, 127, 127,   0, //'W'
 67, 103,  60,  24,  60, 103,  67,   0, //'X'
 7,  79, 120, 120,  79,   7,   0,   0, //'Y'
 71,  99, 113,  89,  77, 103, 115,   0, //'Z'
 0, 127, 127,  65,  65,   0,   0,   0, //'['
 1,   3,   6,  12,  24,  48,  96,   0, //'\'
 0,  65,  65, 127, 127,   0,   0,   0, //']'
 8,  12,   6,   3,   6,  12,   8,   0, //'^'
 128, 128, 128, 128, 128, 128, 128, 128, //'_'
 0,   0,   3,   7,   4,   0,   0,   0, //'`'
 32, 116,  84,  84,  60, 120,  64,   0, //'a'
 65, 127,  63,  72,  72, 120,  48,   0, //'b'
 56, 124,  68,  68, 108,  40,   0,   0, //'c'
 48, 120,  72,  73,  63, 127,  64,   0, //'d'
 56, 124,  84,  84,  92,  24,   0,   0, //'e'
 72, 126, 127,  73,   3,   2,   0,   0, //'f'
 152, 188, 164, 164, 248, 124,   4,   0, //'g'
 65, 127, 127,   8,   4, 124, 120,   0, //'h'
 0,  68, 125, 125,  64,   0,   0,   0, //'i'
 96, 224, 128, 128, 253, 125,   0,   0, //'j'
 65, 127, 127,  16,  56, 108,  68,   0, //'k'
 0,  65, 127, 127,  64,   0,   0,   0, //'l'
 124, 124,  24,  56,  28, 124, 120,   0, //'m'
 124, 124,   4,   4, 124, 120,   0,   0, //'n'
 56, 124,  68,  68, 124,  56,   0,   0, //'o'
 132, 252, 248, 164,  36,  60,  24,   0, //'p'
 24,  60,  36, 164, 248, 252, 132,   0, //'q'
 68, 124, 120,  76,   4,  28,  24,   0, //'r'
 72,  92,  84,  84, 116,  36,   0,   0, //'s'
 0,   4,  62, 127,  68,  36,   0,   0, //'t'
 60, 124,  64,  64,  60, 124,  64,   0, //'u'
 28,  60,  96,  96,  60,  28,   0,   0, //'v'
 60, 124, 112,  56, 112, 124,  60,   0, //'w'
 68, 108,  56,  16,  56, 108,  68,   0, //'x'
 156, 188, 160, 160, 252, 124,   0,   0, //'y'
 76, 100, 116,  92,  76, 100,   0,   0, //'z'
 8,   8,  62, 119,  65,  65,   0,   0, //'{'
 0,   0,   0, 119, 119,   0,   0,   0, //'|'
 char charsel;
 void    dt_lcd_init(void);
 void    dt_lcd_clear_screen(void);
 void    dt_lcd_write_command(char bytefor_command);
 void    dt_lcd_write_data(char bytefor_data);
 void    dt_lcd_write_dorc(char bytefor);
 void    dt_lcd_gotoxy(byte x_col, byte y_row);
 void    dt_lcd_printchar(byte cvar);
 dt_cs=1;
 dt_sclk=1;
 dt_rst = 0;
 delay_ms(10);
 dt_rst = 1;
 delay_ms(1);
 dt_lcd_write_command(0xe2);   // reset
 dt_lcd_write_command(0xa0);   // ADC select: normal
 dt_lcd_write_command(0xc0);   // SHL select:
 dt_lcd_write_command(0xb2);   // LCD bias select:
 dt_lcd_write_command(0x2c);   // Voltage converter ON
 delay_ms(1);
 dt_lcd_write_command(0x2e);   // Voltage regulator ON
 delay_ms(1);
 dt_lcd_write_command(0x2f);   // Voltage follower ON
 dt_lcd_write_command(0x25);   // Regulator resistor select 0x20..0x27
 dt_lcd_write_command(0x81);   // Reference voltage register set
 dt_lcd_write_command(0x18);   // Reference voltage 0..63
 dt_lcd_write_command(0x40);   // initial display line 0x40..0x7f
 dt_lcd_write_command(0xaf);   // display ON
 char xx,yy;
 // RAM set to zero
 for (yy=0;yy!=8;yy++){
 dt_lcd_gotoxy(0,yy);
 printf(dt_lcd_printchar,"                        ");
 //printf("yy=%u ",yy);
 dt_cs=0;
 //nop;nop;nop;nop;
 dt_rs=0;
 dt_lcd_write_dorc(bytefor_command);
 dt_cs=1;
 dt_cs=0;
 //nop;nop;nop;nop;
 dt_rs=1;
 dt_lcd_write_dorc(bytefor_data);   // write display data
 dt_cs=1;
 void dt_lcd_write_dorc(char bytefor)         // serial write data or command subroutine
 char caa;
 for (caa=8;caa>0;caa--) {
 dt_sclk=0;
 // delay_us(2);
 if ((bytefor&0x80)==0){dt_sid=0;}
 else {dt_sid=1;}
 //nop;nop;
 dt_sclk=1;
 bytefor=bytefor<<1;
 //nop;nop;
 void dt_lcd_gotoxy(byte x_col, byte y_row)      // Position cursor
 char hi_col,lo_col;
 //x_col+=0x24;
 lo_col= (x_col&0x0f);
 //printf(" lo_col=%u ",lo_col);
 hi_col= ((x_col>>4)&0x0f)|0x10;
 //printf(" hi_col=%u ",hi_col);
 dt_lcd_write_command(hi_col);      // set higher column address
 dt_lcd_write_command(lo_col);      // set lower column address
 dt_lcd_write_command(0xb0|(y_row&0x0f));   // set GDDRAM page address 0..7 (for 8 rows)
 //printf(" y_row=%u ",y_row);
 void dt_lcd_printchar(byte cvar)               // Write 1 character to LCD
 charsel=cvar;
 int i;
 for ( i = 0; i < 5; i++ ){
 if(charsel<0x50) dt_Lcd_Write_data(TABLE5[charsel - 0x20][i] << 1);
 else if(charsel>0x4f) dt_Lcd_Write_data(TABLE6[charsel - 0x50][i] << 1);
 }          // send data to nokia
 dt_lcd_write_data(0x00);               //    1 byte (always blank)
 void lcd_printchar(byte cvar)               // Write 1 character to LCD
 charsel=cvar;
 int i;
 for ( i = 0; i < 8; i++ ){
 if(charsel<0x50) dt_Lcd_Write_data(font_bold1[charsel - 0x20][i] << 1);
 else if(charsel>0x4f) dt_Lcd_Write_data(font_bold2[charsel - 0x50][i] << 1);
