aaronik19
DataLogging |
Posted: Sun Feb 12, 2012 2:56 pm |
Dear All,
What is the best structure to use to store datalog data in eeprom/MMC? For example I need to store the following structure:
Time - Date - Value - Change.
Will an array be a good solution? Or the best way is to define the locations during the programming on the ccs from the main program?
Looking forward for your comments about this task. In my project I will have the MMC/SD Card interface to store data. |
SherpaDoug
Posted: Sun Feb 12, 2012 4:45 pm |
If you store the data in "CSV" format it is easy to import into PC software such as Excel. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Joined: 01 Jul 2010 Posts: 9506 Location: Greensville,Ontario
Posted: Sun Feb 12, 2012 6:39 pm |
I second using the CSV format! My solar panel loggers use it Date,time,temperature1,temperature2,controlstatus.
Simple ,easy, universal...any program can handle the data format even QuickBasic4.5 !! |
