Rotary Encoder final
Post new topic   Reply to topic    CCS Forum Index -> Code Library
ze.vana
PostPosted: Sun Sep 04, 2011 8:14 am     Reply with quote
Here in my Country there are not dsPIC or PICs with QEI MODULATE ,then I decided to do
that project. This is ROTARY ENCODER'S final version with 32 bits, he measures counterclockwise
and anti-counterclockwise rotations. I've tested it with industrial TTL encoders (Heidenhein and Sick
2500 pulse/revolution , both from Germany) used in CNC machines, and I can guarantee, it makes
measurements super fast, without losing position.
First project:
http://www.ccsinfo.com/forum/viewtopic.php?. I’ve copied the flex_lcd from this Forum, I hope the author does not mind, this Forum has helped me a lot, thanks all you guys!
Email ze.vana@hotmail.com
#include <18F4520.h>
#use delay(clock=40M)
#use  RS232(baud=9600, parity=N, bits=8,xmit=pin_c6, rcv=pin_c7)
#include <flex_lcd.c>
#define tog1 (pin_d6)
#define led (pin_d0)//#define led (pin_d7)em casa é o d0
//#define DIR_1 (pin_d0)
//#define ZERO_2 input(pin_C3)//REFERENC input
#define DIR_2 (pin_d1)
#define ZERO input(pin_d2)
#define MENOS input(pin_d3)
  int1 referen=0;
  char signal;
  int16 tmr0;
  int16 tmr0xn=0;
  int32 result0=0,real;
  #bit pir0=0x0ff2.2 //timer0 overflow
  int16 tmr1;
  int16 tmr1xn=0;
  int32 result1=0;
  #bit pir1=0x0f9e.0 //timer1 overflow
  int1 stopped;
  int8 zerado = 0;
  int16 tmr1H,tmr1L,tmr0H,tmr0L;//see line 129
  int32 MAX=0,MIN=200,MEDIA,differen;//see line 122
#INT_TIMER2
void intt2_isr()
  set_timer2(0);
  tmr1=GET_TIMER1();   //get counter UP value
  tmr0=GET_TIMER0();  //get counter DOWN value
 // differen= result1 - real;
 if(pir1==1)
tmr1xn++;
pir1=0;
if(pir0==1)
tmr0xn++;
pir0=0;
 //--auto zero--------------------------             //positive
if(differen > 200000 && stopped==1 && zerado != 1 && signal== 43 && real < 65000)//zerar 1
   { //see line 131
  result1= media;
  set_timer1(media);
  set_timer0(0);
  tmr0xn=0;
  tmr1xn=0;
  zerado=1;
   }                                                 //positive
if(differen > 200000 && stopped==1 && zerado != 2 && signal== 43 && real < 65000)//zerar 2
   { //see line 150
  result1= media;
  set_timer1(media);
  set_timer0(0);
  tmr0xn=0;
  tmr1xn=0;
  zerado=2;
 //----auto zero--end--------------------
if(referen==0 && zero_2==1)
  result1= 0;
  set_timer1(0);
  set_timer0(0);
  tmr0xn=0;
  tmr1xn=0;
  referen=1;
#INT_TIMER3
  void ext3_isr()
  SET_TIMER3(0);
min=max;
if(real < min)
  min= real;
if(real > max )
  MAX =real;
if(max  > min )
  media = min;
  media= max;
void main(){
  set_tris_a(0xff);
  set_tris_b(0xff);
  set_tris_c(0xff);
  SET_TRIS_D(0x00);
  output_d(0x00);
 //TIMER0 16 bits as counter /DOWN
  SETUP_TIMER_0(RTCC_EXT_H_TO_L|RTCC_DIV_1);
      SET_TIMER0(0);
      DISABLE_INTERRUPTS ( GLOBAL );
  // TIMER1 16 bits as counter /UP
  SETUP_TIMER_1(T1_EXTERNAL | T1_DIV_BY_1 );
      ext_int_edge(H_TO_L);
      set_timer1(0);
 //TIMER2 INTERNAL
  SETUP_TIMER_2( T2_DIV_BY_1,0xc0,2);
      set_timer2(0);
      enable_interrupts(int_timer2);
      enable_interrupts(global);
 //TIMER3 INTERNAL
  SETUP_TIMER_3(T3_INTERNAL |T3_DIV_BY_4); // TIMER3 INTERNAL
     SET_TIMER3(1000);
     enable_interrupts(INT_TIMER3 );
  lcd_init();//It must be here or else you got instability.
   stopped=1;
   tmr1L=0; tmr1H=100;tmr0L=0;tmr0H=100;
 while(true)
  tmr1L=GET_TIMER1();  //get timer0/1 initial value
  tmr0L=GET_TIMER0(); //see line 150
  differen= result1 + result0;//value to zero encoder
  result0=(65536 * tmr0xn) + tmr0;//gets 32 bits timer0/1
  result1=(65536 * tmr1xn) + tmr1;
 if(result1 >= result0)
 real= result1 -result0;// get plus real value
    signal='+';
 real= result0 -result1;// get minus real value
   signal='-';
  printf(LCD_PUTC"\f\%c%Lu %Lu\n",signal,real,differen );
  printf(LCD_PUTC "\n1:%Lu 0:%Lu",result1,result0 );
  //printf("\f r:%lu t1:%lutmr1xn:%lu", result0 ,tmr0,tmr0xn);tests
 //printf("\f %u",signal );
 tmr1H=GET_TIMER1();  // get timer0/1 final  value
 tmr0H=GET_TIMER0(); //see line 119
 if(tmr1H == tmr1L && tmr0H == tmr0L)// if all equal, encoder is stopped
    {                               //see line 129
delay_ms(700);
 stopped=1;//flag
 output_high led;
stopped=0;
output_low led;
quadro
PostPosted: Thu Feb 09, 2012 7:43 am     Reply with quote
Thanks for very useful code.
I'm working on position and speed reading, but I'm using 18f4431.
18f4431 has some disadvantages (program memory low, price high...).
I have a lot of 18f46k20. Your code is a big advantage for me. Thanks.
ze.vana
PostPosted: Thu Feb 09, 2012 3:00 pm     Reply with quote
Thanks for appreciating.
Well I have received some questions on how it works, then as my english is not so good. And I think this code could be a little difficult to understand, I am putting the basic code.
The used additional Hardware I can send by email for who want.
BASIC CODE:
//BASIC CODE
#include <18F4520.h>         //<18F452colt.h> or  coltbootloader
//encoder--------------------------------------------encoder-----
 int16  T0,T1,R; //float R; //R is the result from T1-T0
 void print_lcd(void){
   T1= GET_TIMER1(); //get counter UP value
   T0= GET_TIMER0(); //get counter DOWN value
   R= T1-T0;         //R is the result from Timer1-Timer0
   printf(LCD_PUTC"\f\REAL:%Lu \n",R);
   printf(LCD_PUTC"\nR=T1:%Lu-T0:%Lu",t1,t0 );
   delay_ms(200);
   if(t0 > t1){    //Tmr0 never can be grater than  Tmr1,
   SET_TIMER0(0); //if so reset Timers
   SET_TIMER1(0);
//#int_timer2
void timer_t2()
  set_timer2(250);
 // lcd_init();
 // delay_ms(100);
 // print_lcd();
//encoder------------end--------------------------encoder--------
void main (void)
 set_tris_a(0xff);
 set_tris_b(0x00);
 set_tris_c(0xff);
 set_tris_d(0xff);
SET_TIMER0(0);
 set_timer1(0);
  lcd_init();
  while(true)
 print_lcd();
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
