paddy Guest
| About the Timer0 interrupt in Pic12c508 or PIC16C54 with cc |
Posted: Tue May 13, 2003 2:44 am |
Dear all,
Who can help me,How can I get the interrupt handle in PIC12c508A or other using the css compiler,The datasheet of the PIC12c508A refer the chip have a timer0,but allways get the error message when I add the #int RTCC or #int timer0,How can I use the only interrupt in this chip?
Thanks in advancecd!
___________________________
Original Post ID: 14397 |
Tomi Guest
| Re: About the Timer0 interrupt in Pic12c508 or PIC16C54 wit |
Posted: Tue May 13, 2003 4:42 am |
Interrupts are not supported by 12-bit core devices.
You can use 14-bit cores (e.g. 12F6XX) instead (or you can poll the timer for overflow).
:=Dear all,
:= Who can help me,How can I get the interrupt handle in PIC12c508A or other using the css compiler,The datasheet of the PIC12c508A refer the chip have a timer0,but allways get the error message when I add the #int RTCC or #int timer0,How can I use the only interrupt in this chip?
:= Thanks in advancecd!
Original Post ID: 14399 |
