Verify file .hex
microlo75
Verify file .hex
PostPosted: Sun Nov 27, 2011 12:24 pm     Reply with quote
Hi forum,
before doing a firmware update with bootloader,
how do I verify a file. hex?
I would check that the CRC is correct, how do I calculate it?
:1082400002003700094EE20004003A0010C0B300FB
:1082500006FFB700608A02000100000089D2AE006C
:1082600002003700FE99020001000000C20CAE00BF
:10827000020037000ABE02000100000012C0040024
:10828000010000004F037800CF02780000000600D4
:00000001FF
;PIC24FJ256GB110
;CRC=F6B9 CREATED="15-nov-11 17:30"
how to calculate the CRC=F6B9???
I did many tests in visual basic but I can not get the result ..
thanks for the help
Alex
gpsmikey
PostPosted: Sun Nov 27, 2011 12:31 pm     Reply with quote
The CRC should be of the data portion of the file, not the ascii file you are looking at (you will have to look at the data portion only to get the same CRC). Take a look at page 3 of this note for the format of the hex file:
http://ww1.microchip.com/downloads/en/AppNotes/91024a.pdf
That said, I would expect the file was created correctly. If you want to validate the entire file later to make sure it was not corrupted, probably the easiest way is to stuff it in a .zip file for example for storage since .zip can include a CRC of the files it stores. You could also use something like an MD5 sum or one of the other formats that people publish along with files you can download to make it easy to verify the download was correct. It depends whether you are trying to validate the data portion of the hex file or verify the entire hex file is valid/has not been altered.
mikey
mikey
PostPosted: Sun Nov 27, 2011 1:35 pm     Reply with quote
Import it into MPLAB. If it has a CRC error, MPLAB will tell you.
Do this with the File / Import menu in MPLAB.
microlo75
PostPosted: Sun Nov 27, 2011 2:41 pm     Reply with quote
tks for reply,
my clients .... "before doing a firmware update of my product with bootloader"
my program has to check the crc of the file...
microlo75
PostPosted: Sun Nov 27, 2011 2:42 pm     Reply with quote
mikey
tks for reply,
for. zip ok, but I should do more operations since the update is automatic via ftp ..
I hope to understand how to calculate the crc ....
PostPosted: Sun Nov 27, 2011 3:24 pm     Reply with quote
The Code Library has efficient code examples for calculating CRC-8 and CRC-16.
CRC-8 wouldn't be safe enough in my opinion, but CRC-16 should do the trick.
PostPosted: Sun Nov 27, 2011 5:08 pm     Reply with quote
I'm not aware of a specification how the CRC16 in CCS hexfiles is calculated, means, which part of the image is used for it.
That's not obvious because the hex files are ususally not continuous.
The said CRC is CCS-specific and not checked by MPLAB.
bkamen
PostPosted: Sun Nov 27, 2011 6:44 pm     Reply with quote
Check out:
http://en.wikipedia.org/wiki/Intel_HEX
PostPosted: Mon Nov 28, 2011 12:20 am     Reply with quote
Check out
Please read the original post thoroughly. It's not about the Intel hex 8-Bit checksum but the CCS private CRC16 in hex files.
There's no CRC involved with Intel hex.
bkamen
PostPosted: Mon Nov 28, 2011 1:57 am     Reply with quote
my bad. sorry
microlo75
solved
PostPosted: Mon Nov 28, 2011 3:23 am     Reply with quote
thanks for the help,
I solved by checking the crc of each line, instead of CRC ccs.
Alex
PostPosted: Mon Nov 28, 2011 3:36 am     Reply with quote
It would be interesting anyway to know the algorithm used by CCS. As a first point, you need to know if it's a file
CRC or a flash image CRC (e.g. with 0xff filling of unused locations). I guess, the former.
Most likely, you have to ask CCS.
