jonpaul Guest
| Printf problems |
Posted: Mon May 12, 2003 4:07 pm |
I'm having trouble with printf statements. More specifically, I have a menu I want to display with options over a serial port to be picked up by hyperterminal. However, when I run the code I don't get a nice left justified menu, but more of a waterfall effect. It seems my \n isn't a true line feed. What is going on? This seems like there should be a simple fix, but I'm at a loss.
Here's the code:
do
printf("Welcome to the TB2 Flash Configurator\n");
printf("Please pick from the following options:\n");
printf("(1) Read flashID\n");
printf("(2) Write flashID\n");
printf("(3) Read Rindex\n");
printf("(4) Write Rindex\n");
printf("(5) Print array contents\n");
printf("(6) Write array contents\n");
printf("(7) Print memory contents\n");
printf("Choice: ");
choice=getc();
Any clues?
Jon-Paul
___________________________
Original Post ID: 14387 |
| Re: Printf problems |
Posted: Mon May 12, 2003 4:15 pm |
:=I'm having trouble with printf statements. More specifically, I have a menu I want to display with options over a serial port to be picked up by hyperterminal. However, when I run the code I don't get a nice left justified menu, but more of a waterfall effect. It seems my \n isn't a true line feed. What is going on? This seems like there should be a simple fix, but I'm at a loss.
It's a line feed only. That's the problem. With CCS,
you need to use "\r" to get the carriage return.
Example:
printf("Hello World\n\r");
You should review the example files to see how CCS does things.
The files are in this folder: C:\Program Files\Picc\Examples
Original Post ID: 14388 |
