azykazy
PWM half Bridge Problem |
Posted: Wed Oct 05, 2011 3:43 am |
Hi All,
I have a problem making the half bridge PWM work on 18F4550.
#include<18f4550.h>
#use delay(clock=20000000)
unsigned int pwm1;
pwm1=0;
setup_ccp1(CCP_PWM_HALF_BRIDGE | CCP_PWM_H_H);
setup_timer_2(T2_DIV_BY_16, 249, 1);
pwm1=120; //duty cycle
set_pwm1_duty(pwm1);
When i simulate on Proteus, P1A has an output and P1B is 0.
Any ideas?
Compiler Version is 4.093 |
Posted: Wed Oct 05, 2011 7:34 am |
You need to set the TRIS.
The compiler unfortunately gets confused by using the standard PWM commands, and doesn't realise that TRIS D5, needs to be set to zero for P1B to output.
#include<18f4550.h>
void main(void) {
unsigned int pwm1;
pwm1=0;
output_drive(PIN_D5);
do {
} while(TRUE); //This avoids the compiler error message
Best Wiishes |
azykazy
Posted: Wed Oct 05, 2011 7:41 am |
I have tried it and it works!
Much appreciated! |
