Interrupt priority in the PIC24 family?
blups
PostPosted: Mon Aug 15, 2011 12:49 am     Reply with quote
Hi peeps,
I need to understand the interrupts priority in th pic24 families. I am giving the following scenario:
The RDA Interrupt is set with priority level 1 and the Timer0 overflow with priority level 2.
The program counter is standing in the Timer0 overflow interrupt procedure (is actually in Timer0 Interrupt). At this time happens the RDA event and the PIC gives it major priority. Now what happens, when the PIC is ready with the RDA Interrupt handling?
Goes the PC(Program counter) back to the Timer0 overflow interrupt procedure (in the interrupt) to finish it or goes it outside and wait for new event (interrupt event)?
Much 10x in advance for any help and support,
GR
FvM
PostPosted: Mon Aug 15, 2011 3:34 am     Reply with quote
If nested interrupts are enabled (PCD doesn't by default) and a lower priority interrupt function has been interrupted by a higher priority one, then the lower priority function will be continued after the higher priority service is finished.
To make nested interrupts work in PCD without risking stack overflow, the stack frame should be considerably enlarged above the default assignment.
