CCS C compiler evaluation version for PIC18 series
rabmerab
PostPosted: Fri Jul 15, 2011 4:22 pm     Reply with quote
I am using PCW compiler evaluation version IDE version 3. 36.
The following code compile and run for 16F877A ( include <16F877A.h>) but but does not compile for 18F4458 ( include<18F4458.h>).
The compiling error is ' Unkown device type "PIC18F4458" ' and the world PIC18F4458 near the #device directive in 18F4458.h file is highlighted.
Because I am using e evaluation version of the CCS c compiler does this mean that this compiler works only for the PIC16 series and under or what is the problem?
This just a small program for me to experiment with PIC18F4458
Thanks for you help.
#include<18F4458.h>
#use fast_io(B)
#fuses HS,NOWDT,NOLVP
   set_tris_b(0x00);
   output_b(0xff);  // turn LEDs on
   output_b(0x00); // turn off LEDs
PostPosted: Fri Jul 15, 2011 4:37 pm     Reply with quote
Please don't start a new thread. Add all new replies to your existing thread.
rabmerab
PostPosted: Fri Jul 15, 2011 4:39 pm     Reply with quote
Sorry, I am just new. I will close this thread.
