Problem during power-up
Leef_me
PostPosted: Fri Jul 15, 2011 4:41 pm     Reply with quote
I have a project that is to be powered from 2) 1.5 cells in a battery holder which has clip-leads. The open and in-circuit output of the battery is >=3v
When using the ICD-U64 starting the project works fine.
When I attempt to disconnect the ICD and power the project only from the battery, the project may or may not start.
Can anyone provide helpful suggestions?
To simplify troubleshooting, I have replaced the project software with the "blink LED" example that is generated by the PIC Wizard.
I am using a x10 scope probe to monitor the toggling signal.
The inconsistent startup problem remains.
I do not have a strong knowledge of the internal oscillator, but I do know need it with a clock speed of 16 mhz. Perhaps I have selected or failed to select fuse options that I need.
I have been considering the idea of starting at a lower clock speed and switching to the 16mhz after proper start-up. But I don't know if this might help or is just a waste of time.
From a hardware standpoint, I have the Vpp, Rx and RB0 pulled to Vcc by 100k resistors; the ICD signals "clock" and "data" are unconnected when the U64 is not in place.
I have PCHW compiler / IDE at rev 4.099
I have a ICD-U64 Product ID 194 Firmware 2.87 PCB rev 2
I have CCSLOAD V 4.018
#include <18F24K20.h>
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
//#FUSES BORV22           //Brownout reset at 2.2V
#FUSES PUT           //Power Up Timer
#FUSES NOSTVREN                 //Stack full/underflow will not cause reset
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES NODEBUG          //No Debug mode for ICD
#FUSES NOIESO     //Internal External Switch Over mode disabled
#FUSES MCLR   // Master Clear pin enabled
//#FUSES BROWNOUT               //yes brownout reset
//#FUSES DELAYINTOSC
//#FUSES NODELAYINTOSC
//#FUSES IESO       //Internal External Switch Over mode enabled
// default
//#FUSES NOFCMEN       //Fail-safe clock monitor disabled
//#FUSES FCMEN         //Fail-safe clock monitor enabled
//#FUSES CCP2B3        //CCP2 input/output multiplexed with RB3
//#FUSES CCP2C1        //CCP2 input/output multiplexed with RC1
//#FUSES NOMCLR   // Master Clear pin used for I/O
#use delay(int=16000000)
#define LED PIN_C6
#define DELAY 10
   setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
   setup_oscillator(OSC_16MHZ|OSC_INTRC|OSC_PLL_OFF);
    //Example blinking LED program
    while(true){
      output_low(LED);
      delay_ms(DELAY);
      output_high(LED);
      delay_ms(DELAY);
During my tests, I switch between using the U64 and disconnecting the RJ12 cable at the U64.
I notice that I sometimes have trouble re-establishing communications between the U64 and the target.
Can anyone suggest "proper procedures" for both disconnecting and re-connecting?
Thanks in advance Leef_me
PostPosted: Sat Jul 16, 2011 2:26 am     Reply with quote
Start by enabling the brownout. Though this is designed to ensure a clean reset from a 'glitch', it'll also help to ensure a clean power up, if your supply line is slow in rising - if you have perhaps too much capacitance on the rail, and rather a lot of resistance in the line.
Then check how far above 3v the battery is?. 3.5v, is the maximum recommended for the chip, and it can go into a lockup state if you go above this.
Consider adding a reset circuit to the MCLR connection. A diode and resistor to hold this low for a moment when the supply is attached. Will have to be disconnected when using the ICD.
Enable STVREN. Though it should never happen, it is better to have the chip cleanly reset if a stack overflow takes place, than to go wandering through code, and generate garbage...
