kongfu1
| Can't wakeup PIC16F882 from sleep! |
Posted: Thu Jul 14, 2011 3:08 pm |
PIC16F882
MPLAB: 8.66
CCS: 4.122
With a push button connected RB1 and Vdd. From a scope, it is always from low to high when pushing on it. But this never wake up this chip from sleep. What is wrong?
#include <16F882.h>
#use delay(clock=4M, crystal)
#fuses HS,MCLR,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NOCPD
int sleepFlag = 1;
//external IO is connected to port B RB1 pin
#INT_RB
void PushButtonISR(void)
if(sleepFlag)
sleepFlag = 0;
sleepFlag = 1;
void main (void)
enable_interrupts(INT_RB);
ext_int_edge(L_TO_H); // init interrupt triggering for button press
if(sleepFlag)
sleep();
output_toggle(PIN_C6);
Please help. |
Posted: Thu Jul 14, 2011 3:50 pm |
You have to read Port B inside the #int_rb routine, to clear the "change"
condition, which clears the source of the interrupt. This is in the PIC data
sheet, in the Interrupt-On-Change section. (Or you could read the RB1 pin).
If you don't read Port B in the isr, you will get the interrupt continuously
and the program will spend nearly all of its time executing the isr over
and over again. |
kongfu1
Posted: Thu Jul 14, 2011 4:39 pm |
| PCM programmer wrote: | You have to read Port B inside the #int_rb routine, to clear the "change"
and over again. |
Thanks PCM. |
kongfu1
| Made some changes and result is same |
Posted: Thu Jul 14, 2011 6:05 pm |
and over again. |
Following your suggestion and made following changes. The result is same.
From the scope, C7 was never become high but B1 was changing between 0-5V every time when the button was pushed.
#include <16F882.h>
int sleepFlag = 1;
#INT_RB
int theByte;
output_toggle(PIN_C7);
theByte = input_change_b( );
if(sleepFlag)
sleepFlag = 0;
sleepFlag = 1;
void main (void)
output_low(PIN_C7); //make sure C7 is low for next interrupt
if(sleepFlag)
sleep();
Thanks for helps. |
Posted: Thu Jul 14, 2011 6:28 pm |
Try it with a program that doesn't use sleep. See if it works on your
hardware. This program only enables interrupt-on-change on pin B1.
So I think it is more limited and has a better chance to work.
#include <16F882.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#define SW_PIN PIN_B1
#define LED_PIN PIN_C7
#int_rb
void rb_isr(void)
int8 value;
output_toggle(LED_PIN);
delay_ms(10);
value = input(SW_PIN);
int8 temp;
output_low(LED_PIN);
temp = input(SW_PIN);
clear_interrupt(INT_RB);
enable_interrupts(INT_RB1);
Posted: Fri Jul 15, 2011 2:26 am |
Also note PCM leaving out the ' ext_int_edge' command. This is not available on INT_RB. It is for the INT_EXT (hence 'ext' in the command).
INT_RB, is called whenever a port pin changes. No 'direction' control (there is direction control on some chips, but not your's, and not using this command....).
As a comment, if you are only wanting to use RB1, then enable the interrupt with:
which will only enable them on this one pin.
Also using the 'input_change_b' function is rather pointless, since the fact the interrupt has been called, says 'there has been a change'. What you will need to work out is the direction, so:
#INT_RB
void PushButtonISR(void) {
int8 current_value;
current_value = input_b( );
if (bit_test(current_value,1)==1) {
//Change must be low to high, since pin is now high
//Only correct if INT_RB1 alone selected.
if(sleepFlag)
sleepFlag = 0;
sleepFlag = 1;
kongfu1
| The problem is solved. Great. Thanks for everyone's helps. |
Posted: Fri Jul 15, 2011 11:22 am |
Thanks for everyone's help. The problem is solved. See code below.
#include <16F882.h>
int8 sleepFlag = 1;
#int_rb
void rb_isr(void)
int8 value;
delay_ms(10);
if(value)
if(sleepFlag)
sleepFlag = 0;
sleepFlag = 1;
int8 temp;
if(sleepFlag)
sleep();
