Einly Guest
| internal eeprom 16f876 |
Posted: Sat May 10, 2003 1:40 am |
Dear all,
I am trying to write and read from the internal eeprom of pic 16f876 with the following code:
#include <16f876.h>
#fuses hs,nowdt,noprotect,put,brownout,nolvp
#include <lcd.c>
#byte portc=7
char c;
set_tris_c(0);
write_eeprom(0,'A');
c=read_eeprom(0);
lcd_putc(c);
It works ok. When I changed to write_eeprom(256,'B', I still able to read B on the LCD. However, from what I read, the address is only from 0x255, why I still able to read when I wrote 256, or ever 1000 in the add part?
Thanks in advance:-)
___________________________
Original Post ID: 14336 |
| Re: internal eeprom 16f876 |
Posted: Sun May 11, 2003 3:21 pm |
:= write_eeprom(0,'A');
:= c=read_eeprom(0);
:=It works ok. When I changed to write_eeprom(256,'B', I still able to read B on the LCD. However, from what I read, the address is only from 0x255, why I still able to read when I wrote 256, or ever 1000 in the add part?
The valid address range is from 0x00 to 0xFF. If you try
to use a larger address value, such as 0x100 (256), the
compiler will only use the lower 8 bits. So if you use 0x100,
the compiler converts it to 0x00 when the code is compiled.
Original Post ID: 14362 |
