Delay Using Timer1
raflab
Delay Using Timer1
PostPosted: Thu Aug 11, 2011 3:33 am     Reply with quote
I'm trying to create a delay with N minutes using timer 1 .. I found the following code
#include <16F628A.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
int16 delay = 0;
SET_TIMER1(delay);
SETUP_TIMER_1(T1_INTERNAL | T1_DIV_BY_8);
   if(GET_TIMER1() <32768)
      OUTPUT_LOW(PIN_A1);
   if(GET_TIMER1() >32768)
      OUTPUT_HIGH(PIN_A1);
So if is it possible I want to replace the 0.5 sec by 2 minutes ( for example )
( I said N minutes because that's related to the user that he will be able to send it through VB interface using Serial port communication )
I won't use the delay_ms because it will be imprecise
Thanks Smile)
PostPosted: Thu Aug 11, 2011 1:47 pm     Reply with quote
Most people would do the counting in a Timer1 interrupt routine.
And maybe some people would put a 32.768 KHz watch crystal (with
capacitors) on the Timer1 oscillator pins and have it interrupt once
per second, and count seconds in the interrupt routine.
There is a somewhat complicated example here of the 1st method
(ie. no watch crystal):
http://www.ccsinfo.com/forum/viewtopic.php?t=26177
raflab
PostPosted: Fri Aug 12, 2011 4:04 am     Reply with quote
it's really very helpful !!! Thanks =)))
