		| Author | Message |
		| lxc032
				| ADC IN PWMMING |
				|  Posted: Mon Jul 18, 2011 3:09 pm |   |
				| Dear All,
 I'm doing a project about PWM Dimming using ADC. I'm using a variable resistor to do ADC but the dimming effect is not obvious. My code is shown as follows.
  	  | Code: |  	  |
 #include <16F877A.h>
 #device adc=10
 #fuses XT,NOWDT,NOPROTECT,NOLVP, NOBROWNOUT,NOPUT
 void main() {
 int8 temp_res=0;
 int8 temp_duty=0;
 setup_timer_2(T2_DIV_BY_4,100,1);
 set_tris_a(0xFF);*/
 set_tris_c(0x00); // Set PORTC as an Output
 setup_ccp1(CCP_PWM);
 while(1){
 set_adc_channel(0);
 delay_us(20);
 temp_res = read_adc(); // Get results of AD conversion
 delay_us(20);                           // from channel 2 (RA2 pin)
 temp_duty = (temp_res); // Convert the 10 bit value
 set_pwm1_duty(50);
 delay_us(10);
 Should I change the mutiple of (temp_res) to make the effect more obvious?
		| PCM programmer
		| lxc032
				|  Posted: Mon Jul 18, 2011 3:46 pm |   |
				| Thanks for your program.
 I'm trying to use a variable resistor to change the duty cycle of the PWM signals. Should I need to change the multiple of the "temp_res" ?
		| PCM programmer
				|  Posted: Mon Jul 18, 2011 3:51 pm |   |
				| You are not using the adc value to set the PWM duty.   You are doing nothing with it.  Your PWM duty is set to a constant value of 50.
 The program that I gave you in the link does use the ADC value
 to set the duty.  I suggest that you study it.
