3 Wire LCD with 4094 Shift Register
Post new topic   Reply to topic    CCS Forum Index -> Code Library
sshahryiar
PostPosted: Thu Aug 27, 2015 4:54 am     Reply with quote
LCD.h
#define SDO pin_A0
#define SCK pin_A1
#define STB pin_A2
#define clear_display 0x01
#define goto_home 0x02
#define cursor_direction_inc (0x04 | 0x02)
#define cursor_direction_dec (0x04 | 0x00)
#define display_shift (0x04 | 0x01)
#define display_no_shift (0x04 | 0x00)
#define display_on (0x08 | 0x04)
#define display_off (0x08 | 0x02)
#define cursor_on (0x08 | 0x02)
#define cursor_off (0x08 | 0x00)
#define blink_on (0x08 | 0x01)
#define blink_off (0x08 | 0x00)
#define _8_pin_interface (0x20 | 0x10)
#define _4_pin_interface (0x20 | 0x00)
#define _2_row_display (0x20 | 0x08)
#define _1_row_display (0x20 | 0x00)
#define _5x10_dots (0x20 | 0x40)
#define _5x7_dots (0x20 | 0x00)
#define dly 0x01
unsigned char data_value = 0x00;
void SIPO();
void LCD_init();
void LCD_command(unsigned char value);
void LCD_send_data(unsigned char value);
void LCD_4bit_send(unsigned char lcd_data);
void LCD_putstr(char *lcd_string);
void LCD_putchar(char char_data);
void LCD_clear_home();
void LCD_goto(unsigned char x_pos, unsigned char y_pos);
LCD.c
#include "lcd.h"
void SIPO()
    unsigned char clk = 0x08;
    unsigned char temp = 0x00;
    temp = data_value;
    output_low(STB);
    while(clk > 0)
        output_bit(SDO, (temp & 0x80));
        output_high(SCK);
        temp <<= 1;
        clk--;
        output_low(SCK);
    output_high(STB);
void LCD_init()
    unsigned char t = 0x0A;
    data_value = 0x08;
    SIPO();
    while(t > 0x00)
            delay_ms(dly);
            t--;
    data_value = 0x30;
    SIPO();
    data_value |= 0x08;
    SIPO();
    delay_ms(dly);
    data_value &= 0xF7;
    SIPO();
    delay_ms(dly);
    data_value = 0x30;
    SIPO();
    data_value |= 0x08;
    SIPO();
    delay_ms(dly);
    data_value &= 0xF7;
    SIPO();
    delay_ms(dly);
    data_value = 0x30;
    SIPO();
    data_value |= 0x08;
    SIPO();
    delay_ms(dly);
    data_value &= 0xF7;
    SIPO();
    delay_ms(dly);
    data_value = 0x20;
    SIPO();
    data_value |= 0x08;
    SIPO();
    delay_ms(dly);
    data_value &= 0xF7;
    SIPO();
    delay_ms(dly);
    LCD_command(_4_pin_interface | _2_row_display | _5x7_dots);
    LCD_command(display_on | cursor_off | blink_off);
    LCD_command(clear_display);
    LCD_command(cursor_direction_inc | display_no_shift);
    data_value &= 0xFB;
    SIPO();
    LCD_4bit_send(value);
    data_value |= 0x04;
    SIPO();
    temp = (lcd_data & 0xF0);
    data_value &= 0x0F;
    data_value |= temp;
    SIPO();
    data_value |= 0x08;
    SIPO();
    delay_ms(dly);
    data_value &= 0xF7;
    SIPO();
    delay_ms(dly);
    temp = (lcd_data & 0x0F);
    temp <<= 0x04;
    data_value &= 0x0F;
    data_value |= temp;
    SIPO();
    data_value |= 0x08;
    SIPO();
    delay_ms(dly);
    data_value &= 0xF7;
    SIPO();
    delay_ms(dly);
    while (*lcd_string != '\0')
        LCD_send_data(*lcd_string);
        lcd_string++;
    LCD_send_data(char_data);
    LCD_command(goto_home);
void LCD_goto(unsigned char x_pos,unsigned char y_pos)
    if(y_pos == 0)
        LCD_command(0x80 | x_pos);
        LCD_command(0x80 | 0x40 | x_pos);
Example:
#include <12F675.h>
#device *= 16
#fuses NOWDT, PROTECT, CPD, NOMCLR, INTRC_IO, BROWNOUT, PUT
#use delay (internal = 4MHz)
#include "lcd.c"
void setup();
    char txt1[] = {"MicroArena"};
    char txt2[] = {"SShahryiar"};
    setup();
    LCD_goto(3, 0);
    LCD_putstr(txt1);
    LCD_goto(3, 1);
    LCD_putstr(txt2);
void setup()
    disable_interrupts(GLOBAL);
    setup_ADC(ADC_off);
    setup_ADC_ports(no_analogs);
    setup_timer_0(T0_internal);
    setup_timer_1(T1_disabled);
    set_timer0(0);
    set_timer1(0);
    LCD_init();
    LCD_clear_home();
    delay_ms(200);
https://www.facebook.com/MicroArena
SShahryiar
asmboy
PostPosted: Fri Aug 28, 2015 6:24 pm     Reply with quote
has this ever been BUILT with hardware and checked?
or is this 101% Proteus/Isis ?
sshahryiar
LCD reply
PostPosted: Fri Aug 28, 2015 7:29 pm     Reply with quote
I'm not an absolute believer of simulations and so whatever I do, I do it in real life.... Check this out: https://www.youtube.com/watch?v=XMWXVP_9nwY
Although in the video I tested the code with a ATTiny45, it also works with PICs too....
SShahryiar
asmboy
PostPosted: Fri Aug 28, 2015 7:33 pm     Reply with quote
thats good to see. Nicely done.
Nascimento
PostPosted: Thu Dec 31, 2015 8:04 am     Reply with quote
hi friend you could send the pcb 4094?
ps: google translator
asmboy
PostPosted: Thu Dec 31, 2015 4:05 pm     Reply with quote
i don't understand why you don't use the 74HC595 for which CCS provides a driver in the examples section.
name 74595.c in the DRIVERS folder of your CCS install
here is a link to the datasheet for the 4094 which i do NOT reccomend.
http://www.mouser.com/ds/2/405/cd4094b-439708.pdf
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
