CCS V4.110
NivNavick
CCS V4.110
PostPosted: Mon Jan 31, 2011 9:15 am     Reply with quote
Does anybody know if CCS Compiler v4.110 has the timers issue?
because in 4.114 the timers are not working properly
thanks
P.s I'm using PIC18F46K22
NivNavick
PostPosted: Tue Feb 01, 2011 10:04 am     Reply with quote
anybody?
PostPosted: Tue Feb 01, 2011 10:32 am     Reply with quote
For those not immediately aware what "the timers issue" is, won't it be a good idea to give a short example code that can produce it?
NivNavick
PostPosted: Tue Feb 01, 2011 11:58 am     Reply with quote
Take a look here about the timer issue
http://www.ccsinfo.com/forum/viewtopic.php?t=44564
Do you know if this problem happens in v4.110?
PostPosted: Tue Feb 01, 2011 12:59 pm     Reply with quote
I understand, that "the timer issue", that has been confirmed in the said thread actually is failure of setup_ccp2() for 18F46K22 (and similar chips).
As far as I see, the issue exists since the chip is supported in PCH and has been in fixed in V4.116.
NivNavick
PostPosted: Tue Feb 01, 2011 2:41 pm     Reply with quote
So in v4.110 they still has the bug?
PostPosted: Tue Feb 01, 2011 4:02 pm     Reply with quote
Yes, as far as I see it's using the wrong registers.
