Displaying data from serial port in excel.
MiniMe
PostPosted: Sun Aug 14, 2011 11:21 am     Reply with quote
Hi!
I'm sorry if the topic name sounds like placement in wrong kind of forum.
The feature i love about CCS compiler is very dynamic and efficient way to output data using well known "printf" -s. Outputting data using UART module to PC-s serial port. I'm not sure if I'm using correct terms but i thought that my problem... it could be useful thing to know and that happens to be the thing i need.
The problem:
How i can create connection between serial port (COM port) and MS Excel. Is there a easy way to do it. To display data in real-time for analysis and better understanding purposes.
Thank you in advance!
arunb
RE:
PostPosted: Sun Aug 14, 2011 10:09 pm     Reply with quote
You can do this using VBA (Visual Basic for Applications) quite easily.
Make a VB application that interfaces to the hardware, use the MSCOMM serial port control for this. Establish communication with your hardware, acquire real-time data from the device. Use DDE technique to establish communication with MS Excel.
The MSDN help pages contain excellent tutorials and example codes that demonstrate DDE and MSCOMM control usage.
I made a similar project in Microsoft Visual Basic 6.0 using the above mentioned techniques.
A VB 6.0 application communicated with the hardware device (an ADC card, that consisted of a 16F628 PIC and a MCP 3208 ADC) using the serial port of the computer. The same application interfaced with Excel using DDE.
The system was designed to run on Windows XP/2000, and worked very well, I could plot the acquired in real-time on an Excel chart just like an oscilloscope.
I am not sure if DDE is supported in Windows 7 or Vista you have to check this out.
thanks
a
