zhiwei chan
| Prime8 programmer |
Posted: Mon Jan 10, 2011 9:12 pm |
Hi CCS colleague,
I am a test engineer in Emerson China. I am very interested in your product, Prime8 programmer. Here I have some questions below and hope that you could help.
1. There are 8 ports for the programming. So I think the speed should be fast. Could you tell the comparison between Microchip PM3 and Prime8 ?
2. If the programming time for 1 chip is 30 seconds, could you tell if the total time should be the same, 30 seconds, when programming 8 chips ?
3. I find Prime8 supports command line which is what I expect for production. So does it mean we can call this command lines for programming & verifying 8 ports at the same time ? How to identify them individually ? Is it similar to Microchip PM3 ?
4. I am not able to find the detailed instruction (data sheet) about Prime8, such as command line... So could you send me more info about this product ?
Looking forward to receiving your reply soon. |
