Problem with dspic30F2011 fuse settings
Study
PostPosted: Sat Nov 13, 2010 11:24 am     Reply with quote
Hi friends
I want to start with dspic30F2011 and i wrote simple blink program, it sometimes work when i plug power to it and sometime doesn't work, I think the problem is with fuse bit settings, I want to use it with internal osc X4 and connecting MCLR with pullup to VDD ( i want program it next times again ) I know some fuse settings but not all, so i wrote this fuse setting:
#fuses FRC_PLL4,NOWDT,PUT4,NOBROWNOUT,NODEBUG,NOPROTECT
whats my problem? can you tell me write setting?
Regards
Sorry if i have much mistakes, my english is not good.
Thanks a lot for your helps.
Have a good time
Study
PostPosted: Sat Nov 13, 2010 11:29 am     Reply with quote
I think Auto reset doesn't work properly.
Have a good time
Study
PostPosted: Sun Nov 14, 2010 2:23 am     Reply with quote
Nobody can help? why auto reset sometimes doesn't work? Rolling Eyes
Have a good time
PostPosted: Sun Nov 14, 2010 3:34 am     Reply with quote
The datasheet tells:
The device supply voltage characteristics must meet specified starting voltage and rise rate requirements.
Generally, increasing the power up delay, enabling the brownout reset and the WDT may help to manage situations with irregular supply voltage timing.
subi
DSPIC30F6015 64 bit unsigned declaration
PostPosted: Wed Nov 24, 2010 12:39 pm     Reply with quote
I would like to get to help how can I declaration 64 bit unsigned data.
Thanks,
Subi
PostPosted: Wed Nov 24, 2010 12:44 pm     Reply with quote
The PCD manual says, in the section on Basic and Special types:
Note: All types, except char , by default are signed; however, may be
preceded by unsigned or signed (Except int64 may only be signed) .
http://www.ccsinfo.com/downloads/PCDReferenceManual.pdf
subi
dspic30F6015 data declaration
PostPosted: Wed Nov 24, 2010 1:33 pm     Reply with quote
Dear PCM programmer,
Thanks your answer. It was very good.
Subi
