Unexpected Reboot at PIC 16F876, Why ?
Goto page 1, 2  Next
rodorico
PostPosted: Sun Nov 14, 2010 2:17 pm     Reply with quote
Hi people, I have this problem and I don't know how to resolve it.
I'm executing this c code, and when I send some operations (*move (leftmove, forwardmove, rightmove, leftmovestop....)) at the rs232 from the PC to the PIC, normally when I do it faster (from the key PC), The PIC reboot, and I don't know why.
I attach my main function and the int_rda function:
   /* inicializacion de variables */
   duty_wheel_left = duty_stop;
   duty_wheel_right = duty_stop;
   next_duty_wheel_left = duty_stop;
   next_duty_wheel_right = duty_stop;
   /* configuramos interrupciones del timer2 */
   set_tris_b (0xF0); /* puerto b 0,1,2,3 out, others in */
   //set_timer2 (0);
   //set_timer0(0xFF);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_256); /* configuramos el timer 0*/
   setup_timer_2 (T2_DIV_BY_1, 0x63, 1); /* establece el timer2 para 10Khz */
   enable_interrupts (INT_RDA); /* habilitamos interrupciones rs232 */
   enable_interrupts (GLOBAL); /* habilitamos todas las interrupciones */
   printf("WELCOME");
   /* habilitamos interrupciones */
   //enable_interrupts (INT_RB); /* habilitamos interrupciones en el puerto B */
   //enable_interrupts (INT_TIMER0); /* habilitamos interrupciones del timer0 */
   //enable_interrupts (INT_TIMER2); /* habilitamos interrupciones del timer2 */
   /* inicializamos el valor de los pines */
   output_high (PIN_B1);
   output_high (PIN_B0);
   output_low (PIN_B2);
   high_b2 = false;
   manual_move = true;
   /* bucle infinito */
   while (true) {
      if (starts) {
         read_tpa81(TPA81_ID);
         disable_interrupts(GLOBAL);
         printf("%C\n",setTermalScan);
         printf("%U,%U,%U,%U,%U,%U,%U,%U,%U\n", t[1], t[2], t[3], t[4], t[5], t[6], t[7], t[8], t[9]);
         delay_ms(termalScanPeriod);
#int_RDA
interrupt_RS232 () {
   operation = getc();
   printf("Operacion recibida: %C\n", operation);
   // operation to move the robot forward
   else if (operation == forwardMove) {
      moving_forward =true;
      next_duty_wheel_left = duty_forward_left;
      next_duty_wheel_right = duty_forward_right;
   // operation to move the robot to the backward
   else if (operation == backwardMove) {
      moving_backward =true;
      next_duty_wheel_left = duty_backward_left;
      next_duty_wheel_right = duty_backward_right;
   // operation to move the robot to the left
   else if (operation == leftMove) {
   // operation to move the robot to the right
   else if (operation == rightMove) {
   else if (operation == forwardMoveStop) {
      moving_forward =false;
      if (moving_backward) {
      else {
   else if (operation == backwardMoveStop) {
      moving_backward = false;
      if (moving_forward) {
      else {
   else if (operation == leftMoveStop) {
      else if (moving_backward) {
      else {
   else if (operation == rightMoveStop) {
      else {
   // operation to stop moving the robot
   else if (operation == stopMove) {
   // operation to kwon that the robot is alive
   else if (operation == heartbeat) {
   // operation to start the vigilance
   else if (operation == start) {
      set_timer2 (0);
      set_timer0(0xFF);
      enable_interrupts(INT_RB);
      starts = true;
   // operation to stop the vigilance
   else if (operation == stop) {
      disable_interrupts(INT_RB);
      disable_interrupts(INT_TIMER0);
      disable_interrupts(INT_TIMER2);
      starts = false;
Any Idea....
pmuldoon
PostPosted: Sun Nov 14, 2010 2:34 pm     Reply with quote
My first guess is that you have noise on the PIC power pins when you do the move commands.
Does it reset if you have your motors disconnected?
What chip are you using?
What are your fuse settings?
Do you have capacitors across (all of) the PIC power pins?
How is MCLR terminated?
PostPosted: Sun Nov 14, 2010 3:49 pm     Reply with quote
Since you did not show all your code, one thing I see right off:
#int_RDA
   operation = getc();
The printf in your interrupt routine can cause all
kinds of problems. You are using getc() to fetch one character then try to
PRINTF at least 19 characters immediately after. This will cause your
RS232 buffer to UART overflow and the PIC to hang. If you have the WDT
timer enabled you will get a reset.
rodorico
PostPosted: Sun Nov 14, 2010 5:31 pm     Reply with quote
yes it happens with the motors disconnected
16f876
#fuses XT,NOWDT, NOPROTECT, NOLVP, PUT, NOBROWNOUT
#use delay (clock = 4000000)
#use rs232 (baud = 9600, xmit = PIN_C6, rcv = PIN_C7)
#use I2C(master, sda=PIN_C4, scl=PIN_C3)
No I don't have none capacitors.
watch it here
http://www.x-robotics.com/images/PIC16f876_3basic.gif
Hi pmuldoon, I answer at your quote
Any Idea ?
rodorico
PostPosted: Sun Nov 14, 2010 5:40 pm     Reply with quote
#int_RDA
   operation = getc();
Hi dyeatman,
mm I have enabled the Timer0 interrupts but not the WDT.
And the reset is not occur always that I send that printf.
Anyway tomorrow I'll try without that printf.
The configuration I have for the timer0 no enabled the WDT ?
#int_rb
interrupt_RB()
   /** Interrupcion del sensor de movimiento **/
   if (input(PIN_B6) && !timer_move_sensor) {
      timer_move_sensor = true;
      cicles_delay_move_sensor =    number_cicles_delay_move_sensor;
      if (high_b2) {
         output_low(PIN_B2);
           high_b2 = false;
      else {
         output_high(PIN_B2);
         high_b2 = true;
      printf("%C\n", setMoveAlarm);
   /** Interrupciones de los sensores de luz del siguelineas **/
   if (!input(PIN_B5) && !manual_move)
   else if (input(PIN_B5) && !manual_move)
   if (!input(PIN_B4) && !manual_move)
   else if (input(PIN_B4) && !manual_move)
and the configuration for the timer0:
   set_timer0(0xFF);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_256); /* configure timer0 to 16 ms */
Regards
PostPosted: Sun Nov 14, 2010 9:18 pm     Reply with quote
It would be better if you posted a small, but complete test program that
shows the problem. You can probably cut out a large amount of your
code and still create a program that shows the problem. Try to do that.
Then post it. The program that you post should be compilable with no
errors. Test it before you post it. It must have the #include for the PIC,
and the #fuses, and the #use delay(), and all variable declarations, and
a main().
But remember, if you make the program very short, it will be easier for
us to see the problem. We don't want to look at a lot of code, if the
problem can be shown in just a few lines.
rodorico
PostPosted: Mon Nov 15, 2010 5:10 am     Reply with quote
a main().
Ok i'll try to post a short test program to check.
rodorico
PostPosted: Mon Nov 15, 2010 3:53 pm     Reply with quote
Hi, I'm making some test and this is my conclusion, the problem is at the while(true) loop.
If I no put code inside it works fine, but if I insert code, the pic reboots.
This is the while loop
/* loop */
   while (true) {
      if (starts) {
         delay_ms(1);
and the read_tpa81
void read_tpa81( byte slaveID ) {
   for ( i=0; i<10; i++) {
      i2c_start();
      i2c_write(slaveID);
      i2c_write(i);
      i2c_start();
      i2c_write(slaveID+1);
      t[i] =  i2c_read(0);
      i2c_stop ();
      delay_ms(10);
any Idea....
Regards
PostPosted: Mon Nov 15, 2010 4:05 pm     Reply with quote
I can't really do anything without a (short) complete test program
and the compiler version.
Wayne_
PostPosted: Tue Nov 16, 2010 3:11 am     Reply with quote
I agree with PCM programmer but as you are trying to track the problem down yourself, try commenting out individual lines in the while to see which one causes the reboot!
Also:-
I notice you are accessing your array starting at [1], arrays in C start at base 0 [0], but as you have not posted the variable definition I can not say if this is a problem!
Forget that, I see what you are doing, but still, you don't post ANY variable definitions!
rodorico
PostPosted: Thu Nov 18, 2010 10:44 am     Reply with quote
Here is a short program test,
I'm printing every x second 9 values from a thermal scan connected to the pic by I2c, and attached is all the code of the short program with all the variable declarations.
/* PIN_B6 represents move sensor input  */
/* PIN_B4 represents left line sensor */
/* PIN_B5 represents right line sensor */
/* PIN_B0 represents left wheel */
/* PIN_B1 represents right wheel  */
boolean manual_move;
boolean starts = false;
boolean moving_forward = false;
boolean moving_backward = false;
boolean moving_left = false;
boolean moving_right = false;
char operation;
int i = 0;
byte  t[10];
      i2c_start();
      i2c_write(slaveID);
      i2c_write(i);
      i2c_start();
      t[i] =  i2c_read(0);
      i2c_stop ();
#int_RDA
   operation = getc();
      printf("%C\n", heartbeat);
      set_timer2 (0);
      set_timer0(0xFF);
      starts = true;
      output_low (PIN_B1);
      output_low (PIN_B0);
      starts = false;
   printf("WELCOME\n");
   manual_move = true;
   while (true) {
      for (i = 1; i <10; i++){
         if (i == 9)
            printf("%U",t[i]);
            printf("%U,",t[i]);
      putc('\n');
When I send a lot of commands by rs232 to the robot, it reboots, printing again the WELCOME message.
rodorico
PostPosted: Fri Nov 19, 2010 8:45 am     Reply with quote
any idea guys Rolling Eyes
pmuldoon
PostPosted: Fri Nov 19, 2010 9:10 am     Reply with quote
I don't know if this is the problem or not, but here's a couple of things I would do differently:
Don't enable/disable interrupts in the interrupt routine. Enable them in main() before your infinite loop and leave them enabled. SET or CLEAR a flag in your #int_RDA and use an if(FLAG) to determine whether to execute the code in your other interrupt routines.
Same thing with the printf. Don't printf inside the interrupt. Set a flag and put an if(FLAG)printf(...) in your main loop.
Just my thoughts, but hope it helps.
Add 'errors' to the use rs232(....) function.
Set 'flags' inside the ISR.
Remove all prints,etc. inside the isr.
In the main program loop, test the 'flags' and take the apporopriate action.
pmuldoon
PostPosted: Fri Nov 19, 2010 9:13 am     Reply with quote
Ahh, the ERRORS gotcha!
I missed that completely.
Goto page 1, 2  Next
Page 1 of 2
