Study
| Problem with dspic30F2011 fuse settings |
Posted: Sat Nov 13, 2010 11:24 am |
Hi friends
I want to start with dspic30F2011 and i wrote simple blink program, it sometimes work when i plug power to it and sometime doesn't work, I think the problem is with fuse bit settings, I want to use it with internal osc X4 and connecting MCLR with pullup to VDD ( i want program it next times again ) I know some fuse settings but not all, so i wrote this fuse setting:
#fuses FRC_PLL4,NOWDT,PUT4,NOBROWNOUT,NODEBUG,NOPROTECT
whats my problem? can you tell me write setting?
Regards _________________ Sorry if i have much mistakes, my english is not good.
Thanks a lot for your helps.
Have a good time |
Study
Posted: Sat Nov 13, 2010 11:29 am |
I think Auto reset doesn't work properly. _________________ Sorry if i have much mistakes, my english is not good.
Have a good time |
Study
Posted: Sun Nov 14, 2010 2:23 am |
Nobody can help? why auto reset sometimes doesn't work?  _________________ Sorry if i have much mistakes, my english is not good.
Have a good time |
Posted: Sun Nov 14, 2010 3:34 am |
The datasheet tells: | Quote: | | The device supply voltage characteristics must meet specified starting voltage and rise rate requirements. |
Generally, increasing the power up delay, enabling the brownout reset and the WDT may help to manage situations with irregular supply voltage timing. |
subi
| DSPIC30F6015 64 bit unsigned declaration |
Posted: Wed Nov 24, 2010 12:39 pm |
I would like to get to help how can I declaration 64 bit unsigned data.
Thanks,
Subi |
Posted: Wed Nov 24, 2010 12:44 pm |
The PCD manual says, in the section on Basic and Special types:
| Quote: |
Note: All types, except char , by default are signed; however, may be
preceded by unsigned or signed (Except int64 may only be signed) .
http://www.ccsinfo.com/downloads/PCDReferenceManual.pdf |
subi
| dspic30F6015 data declaration |
Posted: Wed Nov 24, 2010 1:33 pm |
Dear PCM programmer,
Thanks your answer. It was very good.
Subi |
