fix mystery glitches in CCS NCO functions for 16f1509
Post new topic   Reply to topic    CCS Forum Index -> Code Library
asmboy
PostPosted: Fri Jul 11, 2014 9:25 am     Reply with quote
I found that when jamming new frequencies into the NCO using the CCS function that there was frequent glitching of my pulse train.
This is a function that appears to correct the problem.
( NCO used for stepper motor pacing - and the problem
could be HEARD before it was seen )
void setNCOfreq(unsigned int16 pfreq){
    // bank nine page 31 of data sheet
    STATIC int Psetupok;
    #WORD ncoinc=0x49B
  // detect  STOP CMD
  if (!PFreq) {
       setup_nco(NCO_DISABLED|NCO_FIXED_DUTY_MODE|NCO_CLOCK_FOSC,0);
       Psetupok=0;
  else {
      if(0==psetupok){
    setup_nco(NCO_ENABLED|NCO_OUTPUT|NCO_FIXED_DUTY_MODE|NCO_CLOCK_FOSC,pfreq);
        Psetupok=1;
      } // avoid glitches induced when NCO is already generating
      else ncoinc=pfreq;
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
