Retaining OSC1 INT Period w/ Other EXT INTs
jecottrell
PostPosted: Wed Feb 03, 2010 10:37 am     Reply with quote
Hello All,
Been out of this for a while and have jumped back in with a project that uses OSC1 w/ a 32.768XTAL and PCM Programmer's code for a periodic wake up using the PEIE bit.
I've also got INT_EXT enabled to capture another event during sleep. I don't want to reset TIMER1 during the INT_EXT wake so my 'regular' TIMER1 wake events remain spaced at the proper times.
So...
My questions are:
Should I just save the TIMER1 value and adjust before going back to sleep?
How do I capture the TIMER1 value upon wakeup from an INT_EXT?
Any good way to WAG a value for the correction to TIMER1 for the few instructions that get executed during a INT_EXT?
Is there a better way to do this?
Thanks,
John
PostPosted: Wed Feb 03, 2010 10:55 am     Reply with quote
Post a (compilable) test program so we can see what you're talking about.
PostPosted: Wed Feb 03, 2010 11:03 am     Reply with quote
Why should timer1, need to be adjusted at all?.
The timer will stay running at the same rate whether or not the processor is running.
The only errors on timing, will be:
1) If the timer interrupt occurs _while the processor is already handling the external interrupt_, then the service will be delayed till after this has completed.
2) If the external interrupt occurs while the timer interrupt is executing, it will be dleayed till the timer interrupt completes.
3) If both occur within a few uSec of one another, whichever is defined firet, or has it's priority set highest, will be executed first, and the other will be delayed.
4) Be aware, that if you are using a crystal oscillator, there is a very large delay, when the chip awakens, before code is executed, while the oscillator stabilises. This could give problems if latency is important on the external interrupt.
jecottrell
PostPosted: Wed Feb 03, 2010 11:30 am     Reply with quote
Hope you can see what I'm getting at...
(Compilable, but unknown whether it is functional...)
#include <18F2620.h>
#fuses HS, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock=10000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C7,rcv=PIN_C6,bits=8)
#define INT_PERIPHERAL      0xF240  // PEIE for 18F2620
#define TIMER1_CTR_LOAD     4       // Load for the TIMER1 countdown counter (builds the wakeups to desired spacing)
#define INT_OVERHEAD_VALUE  200     // Contrived value to keep Timer1 sleep interrupts spaced correctly
int16   gTimer1_Value       = 0;
int16   gINT_EXT_Tick       = 0;
int1    gINT_EXT_FLG        = false;
int8    gTimer1_CTR         = TIMER1_CTR_LOAD;
#INT_EXT
void INT_EXT_ISR()
    gTimer1_Value   = get_timer1(); // Capture TIMER1 value here to use when we go back to sleep?
    gINT_EXT_FLG    = true;
    gINT_EXT_Tick++;
    clear_interrupt(INT_TIMER1);
    clear_interrupt(INT_EXT);
    enable_interrupts(INT_EXT);
    enable_interrupts(INT_PERIPHERAL);
    while(true)
        if(gINT_EXT_FLG)    // Wake from INT_EXT
            set_timer1(gTimer1_Value + INT_OVERHEAD_VALUE);
        else                // Wake from TIMER1
            if(!gTimer1_CTR--)
                // Regularly spaced events here
                // To include a CCP1 / TIMER1 event
                gINT_EXT_Tick = 0;
                // Reconfigure TIMER1 after CCP1 use
                setup_timer_1(T1_EXTERNAL | T1_DIV_BY_4 | T1_CLK_OUT);
                // Preload timer to adjust wakeups to useable spacing
                set_timer1(4096);
        sleep();
        delay_cycles(1); //dummy instruction for the pre-fetch
jecottrell
PostPosted: Wed Feb 03, 2010 11:34 am     Reply with quote
Ahhhhh.... That makes sense. I'll need to dig into the priorities, etc and see how they'll affect what I'm doing. The timing precision isn't important. Really just looking for something to get done every 5 minutes +/- a second or two and also watch for the INT_EXT while asleep.
Thanks.
