Can anybody help me with LEDs ..thanx..
zack
PostPosted: Sat Jan 30, 2010 6:47 am     Reply with quote
#define suis PIN_D0
#define buzzer PIN_B0
#define buzzer2 PIN_D1
//void delay 20s ()
   //int i;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
  //if (input(suis))
   output_b(0b00000001);
   output_b(0b00000010);
   output_b(0b00000100);
   output_b(0b00001000);
   output_b(0b00010000);
   output_b(0b00100000);
   output_b(0b00000000);
   output_b(0b01000000);
   output_d(0b00000010);
   output_d(0b00000100);
   output_d(0b00001000);
   output_d(0b00010000);
   output_d(0b00100000);
   output_d(0b01000000);
//void delay==20s()
//for(i=0;i<=20;i++)
//delay_ms(1000);}
I want to make an LED running which consist of three different colours of LED. I have a problem for last LED which is connected to Port D. It cannot turn ON. And also I want my LED at port b to turn on for 20s before another LED continues flashing. Please help me.
PostPosted: Sun Jan 31, 2010 12:21 am     Reply with quote
Always post your PIC, and the #fuses, #use delay(), and your compiler
version.
PostPosted: Sun Jan 31, 2010 6:01 am     Reply with quote
This is an (old) error in the CCS setup wizard and creates an invalid hardware configuration with undefined behaviour. Change to:
setup_spi(FALSE);
zack
PostPosted: Tue Feb 02, 2010 7:41 pm     Reply with quote
version.
Thank you. I use PIC16f877A and I use PIC compiler software. I'm a beginner in PIC and I do it for my final project so I actually am not an expert with the software. Hope that you will guide me. Thank you.
