		| Author | Message |
		| RJKING Guest
				| U-64 compatible with PIC18F67J50? |
				|  Posted: Sun Nov 22, 2009 11:50 pm |   |
				| I am having a problem with the U-64 ICD. Compiler version is 4.099. I did try 4.100, but then my ICD2 will not work. So I will describe the problems with 4.099
 With a PICDEM 2 board (PIC18lf4550) both the U-64 and ICD-2 function fine.
 With a Olimex LCD3310 board (PIC18F67J50) the ICD-2 functions fine (with Vpp limiter), but the U-64 gets a target detect error.
 On CCSLOAD, I get a  Target Device ID mismatch.
 Read:   00101011000XXXXX
 Expect: 01000001100XXXXX
 I’ve checked the Olimex board. It had a cap from MCLR to ground, which I removed, to no effect. The pullup to Vcc is 10K on this board, but being the ICD2 was fine with it, I didn’t change it and in any case, the PICDEM2, which the U-64 works fine with, has a lower value pull up on MCLR.  RB6 and RB7 seem to be unloaded on the schematic.
 Any thoughts here?
		| Guest
				|  Posted: Mon Nov 23, 2009 1:28 pm |   |
				| Just give this a try: If you use CCSLOAD 4020.
 * Close all CCS application!
 * Then rename "devices4p.dat" to ex. "devices4p.dat_old".
 if this is not working, try to use a "devices4.dat" from a older version. This fix my problem with 18F26Jxx.
		| Jeff King
				|  Posted: Thu Dec 03, 2009 12:55 pm |   |
				| 4.101 fixed it |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
