What's wrong with this simple code?
noisepic
PostPosted: Wed Oct 26, 2005 10:35 pm     Reply with quote
I want to make a led flash by this code. I use PIC16F88, Crystal 4 MHz
#include<16F88.h>
#fuses  NOWDT,HS,MCLR,NOLVP,NOPROTECT
#use    delay(clock=4000000)
main()
     output_high(PIN_B3);
     delay_ms(300);
     output_low(PIN_B3);
     delay_ms(300);
But the led doesn't flash. What's wrong? I don't think ..by this code!
asmallri
PostPosted: Wed Oct 26, 2005 11:00 pm     Reply with quote
Change the HS fuse to XT
Regards, Andrew
kel
It should still work!
PostPosted: Thu Oct 27, 2005 12:02 am     Reply with quote
there is no problem with the code,I tried the code and it works.Check your circuit and if that is fine then change the HS fuse as indicated by Andrew!
cheers
Wink
neil
PostPosted: Thu Oct 27, 2005 6:29 am     Reply with quote
Is MCLR connected to anything? are you using a pull-up. Try changing the fuse from MCLR to NOMCLR.
Bart
PostPosted: Thu Oct 27, 2005 9:41 am     Reply with quote
And if your led's are to slow,change the delay to 1000. (1 sec on, 1 sec off)
How did you connect the led ? Maybe you inversed it. Did you use a not to high resistor between (need to be somewhere around 330 ohm)
Greetings.
I like Skype (www.skype.com), my username is BplotM
noisepic
PostPosted: Sat Oct 29, 2005 9:58 pm     Reply with quote
I've checked these thing. but my PIC16F88 can't do its job.
I change another 16F88, the failure too!
I don't know why?
asmallri
PostPosted: Sat Oct 29, 2005 11:46 pm     Reply with quote
It looks like a hardware problem.
Is the crystal OK?
Does it have the right value for the load capacitors?
Did you set the fuse to XT?
Are you sure you wired the LEDs the right way around?
Do you have a logic proble you could use to test the output pins?
What value series resistor did you use with the LEDS?
What is the VCC voltage?
What programmer are you using?
When you read back the code using the programmer:
are the fuses correct?
does the code match the hex file?
Regards, Andrew
skel
Are you connecting the right capacitors?
PostPosted: Mon Oct 31, 2005 11:04 pm     Reply with quote
you must have right capacitors across the crystal to the ground.
you must check your mclr too!
check if your ic is working! Rolling Eyes
PostPosted: Tue Oct 13, 2009 8:39 pm     Reply with quote
 #include <16f88.h>
#use delay (clock=1000000)
#fuses NOLVP, NOWDT, INTRC, PUT
void main ()
**here's the header that i normal use for everything. try this out Very Happy
PostPosted: Tue Oct 13, 2009 8:54 pm     Reply with quote
#include <16f88.h>
#use delay (clock=100000)
void main ( )
    setup_oscillator (osc_8mhz);
    setup_adc_ports(no_analogs) ; // all ADC pins to digital I/O
    set_tris_a(0x01);    //bit A0 is input
     while (1) //creates endless loop
          { start:
               if (input(pin_A0))
                   output_bit(pin_B0,1);//LED on
               goto start; //repeat loop at "start"
This is just a little more then what i last posted....but this should definitely work for you. Very Happy
