Measuring Program Cycle
js
PostPosted: Thu Oct 15, 2009 2:02 pm     Reply with quote
How is the way to measure the time of each program cycle ?
PostPosted: Thu Oct 15, 2009 2:23 pm     Reply with quote
To measure the time required for a block of code, you can use the
MPLAB Simulator's Stopwatch feature. This thread has instructions on
how to use it:
http://www.ccsinfo.com/forum/viewtopic.php?t=38351
You can also set an i/o pin high at the start of a routine and low at the
end, and use an oscilloscope or a logic analyzer to see the pulse length,
and thus find the length of the routine.
bkamen
PostPosted: Fri Oct 16, 2009 12:14 am     Reply with quote
I do this a lot.
