Porting code to another PIC Microcontroller
bob_hause
PostPosted: Wed Sep 09, 2009 1:06 pm     Reply with quote
In 2006-2007 I wrote a program for the PIC16F690 using the CCS C-compiler (PCW IDE 3.249 and PCM 3.249).
I am currently developing a new PCB, where I need a PIC microcontroller and I need to use the majority of code already developed for the previous PIC16F690. However I would like to use a more general purpose PIC microcontroller, preferably one in which the VREF and ICSPCLK functions do not share one pin.
I have lots of real estate -- so I can use a larger (i.e., higher pin-count) PIC microcontroller.
Cost of microcontroller is not an issue.
Can anyone suggest another FLASH microcontroller that has ADC input, digital I/O, and in-circuit programmability. I need no other subcircuits. Preferably the most popular general-purpose microcontroller that should be available for the next several years.
Thank you
PostPosted: Wed Sep 09, 2009 1:22 pm     Reply with quote
Probably 16F886 (28-pin package):
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en026562
You can look for others in this list:
http://www.microchip.com/ParamChartSearch/chart.aspx?branchID=1002&mid=10&lang=en&pageId=74
Or use this selector:
http://www.microchip.com/maps/microcontroller.aspx
Set the Prefix for 16F, and then narrow it down from there.
bob_hause
PostPosted: Wed Sep 09, 2009 2:44 pm     Reply with quote
Thank you PCM programmer.
I found an excellent on-line comparison tool at the microengineering labs website (melabs.com) -- I have decided on the PIC16F887.
