Hardware PWM on Pic16f727
kbruin79
PostPosted: Wed Jul 20, 2011 11:53 pm     Reply with quote
I am trying to setup a Harware PWM on Pic16f727. So I followed the steps listed on page 143 of the datasheet for setting up the PWM output on PortC pin2 and I couldn't get the port to output anything. Here is the code any help is highly appreciated:
#include <16F727.h>
#include <math.h>
#include <stdlib.h>
#include <float.h>
//#fuses INTRC_IO,NOWDT,NOPROTECT,NOMCLR,VCAP_A6
//#use delay (internal=4000000) //(clock=4M)
#fuses   INTRC_IO, NOWDT, NOPROTECT, NOMCLR
#use     delay(clock = 4000000)
#include <flex_lcd.c>
#use     fast_io (A)
// setting up PWM parameters
#byte PR2=0x92
#byte T2CON=0x12
#byte CCP1CON=0x17
#bit  CCP1CON_4=CCP1CON.4
#bit  CCP1CON_5=CCP1CON.5
#byte CCPR1L=0x15
#byte PIR1=0x0C
#bit PIR1_1=PIR1.1
//interrupt variables
#byte TMR0=1
#bit  TMR0_0=TMR0.0
#bit  TMR0_1=TMR0.1
int16     duty=0;
#bit duty_0=duty.0
#bit duty_1=duty.1
//Disable the PWM pin (CCPx) output driver(s) by
//setting the associated TRIS bit(s).
TRISIOC_2=1;
//Load the PR2 register with the PWM period value.
PR2=249;              // 1 khz
//Configure the CCP module for the PWM mode
//by loading the CCPxCON register with the
//appropriate values.
CCP1CON=0b00001100;   // Set CCP1 PWM active high
//Load the CCPRxL register and the DCxBx bits of
//the CCPxCON register, with the PWM duty cycle
//value.
duty = 0;               // set duty cycle to 0
CCP1CON_4 = duty_0;     // Store duty to registers as
CCP1CON_5 = duty_1;     // a 10-bit word
//store the eight MSbs in CCPR1L.
CCPR1L = duty >> 2;     // store the remaining low byte
//clear the TMR21F interrupt flag bit of PIR1 register
PIR1_1=0;
//Configure the T2CKPS bits of the T2CON
//register with the Timer2 prescale value.
//and
//Enable Timer2 by setting the TMR2ON bit of
//the T2CON register.
T2CON: TIMER2 CONTROL REGISTER
   TMR2ON: Timer2 On
   1 = Timer2 is on
   0 = Timer2 is off
   T2CKPS<1:0>: Timer2
   00 = Prescaler is 1
   01 = Prescaler is 4
   1x = Prescaler is 16
T2CON=0b00000111;
//Wait until Timer2 overflows, TMR2IF bit of the
//PIR1 register is set.
wait_for_TMR2IF:
if (PIR1_1 == 0)
  goto wait_for_TMR2IF;
//enable PWM by setting pin to output
TRISIOC_2=0;
//make portA pin 7 an output
TRISIOA_7=0;
   pwm(1000);
void pwm(int16 a2d)
   CCPR1L = duty >> 2;    // store the remaining low byte}
   //GIE re-enable the global interrupts
   //INTCON_7=1;
asmboy
how about htis way??
PostPosted: Thu Jul 21, 2011 3:40 pm     Reply with quote
This is the CCS forum - not the hack-assembler-into-c
when CCS has already done the heavy lifting 4 U !!
i suggest you read the fucntional overview section of the CCS manual
entitled CCP1 and C if U don't start to get somewhere with your
PWM project.
hint:
setup_ccp1()
and set_pwm_duty()
are about all you need
