PIC RS232 Transmission
PIC2OLED
PostPosted: Wed Sep 09, 2009 10:08 am     Reply with quote
Hi I am using the pic16f818 and I am using the A/D converter to generate an 8bit number. I want to transmit that number via rs232. I am sure I connected everything fine, but somehow the PIC is sending 1s all the time. Sad
And I have no clue at all what the problem might be, because before I send it I flash LEDs such that they represent the value and they flash properly i.e not all are lit up Shocked
Here is my code:
#include <16F818.h>
#DEVICE ADC=8;
#use rs232(BAUD=9600, XMIT=PIN_B2, RCV=PIN_B1, BITS=8, PARITY=N)
#fuses HS, NOWDT, NOBROWNOUT, NOPUT
unsigned int8 value;                                 //declare variable value which is an 8 bit number
   SET_TRIS_B(0b00001010);                        //0 means output, 1 means input; output pins B4 to B7 and B2
   SET_TRIS_A(0b00100011);                        //0 means output, 1 means input;
   output_bit(Pin_B4, 1);                        //just flashing LEDS at beginning to make sure it is all fine
   output_bit(Pin_B5, 1);
   output_bit(Pin_B6, 1);
   output_bit(Pin_B7, 1);
   output_bit(Pin_A2, 1);
   output_bit(Pin_A3, 1);
   output_bit(Pin_A4, 1);
   output_bit(Pin_B0, 1);
   output_bit(Pin_B4, 0);
   output_bit(Pin_B5, 0);
   output_bit(Pin_B6, 0);
   output_bit(Pin_B7, 0);
   output_bit(Pin_A2, 0);
   output_bit(Pin_A3, 0);
   output_bit(Pin_A4, 0);
   output_bit(Pin_B0, 0);
   printf("U");                                 //Send a U to the uOLED for baud detect
   SETUP_ADC_PORTS(AN0);               SETUP_ADC(ADC_CLOCK_INTERNAL);
   delay_ms(10000);
   do{
      SET_ADC_CHANNEL(0);
      delay_us(50);
      value=READ_ADC(ADC_START_AND_READ);           //start converting
      delay_us(50);
      putc(value);                           //send value
      //flash LEDs  such that they represent value
      output_bit(Pin_B4, bit_test(value,0));
      output_bit(Pin_B5, bit_test(value,1));
      output_bit(Pin_B6, bit_test(value,2));
      output_bit(Pin_B7, bit_test(value,3));
      output_bit(Pin_A2, bit_test(value,3));
      output_bit(Pin_A3, bit_test(value,5));
      output_bit(Pin_A4, bit_test(value,6));
      output_bit(Pin_B0, bit_test(value,7));
   } while (TRUE);
PostPosted: Wed Sep 09, 2009 12:04 pm     Reply with quote
Make a simple program that only reads the ADC and sends the result
to a terminal window on your PC. Examples:
This program sends the ADC value in Hexadecimal format to the PC:
http://www.ccsinfo.com/forum/viewtopic.php?t=34386&start=1
This program converts the ADC value to a voltage and sends it to the PC:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168&start=1
