Marcel Tschopp Guest
| ICD2 cannot program my 16F877 |
Posted: Tue Apr 15, 2003 2:48 am |
Hi<p>
My Problem is following (listing from MPLAB):<p>
Connecting to MPLAB ICD 2
...Connected
Setting Vdd source to MPLAB ICD 2
<b>ICDWarn0020: Invalid target device id (expected=0x4D, read=0x0)</b>
...Reading ICD Product ID
Running ICD Self Test
...Passed
MPLAB ICD 2 Ready
Programming Target...
...Erasing Part
...Programming Program Memory
...Loading DebugExecutive
...Programming DebugExecutive
...Programming Debug Vector
...Programming Configuration Bits
Verifying...
...Program Memory
<b>ICD0161: (CMemory::Verify) Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x3000, Val Read = 0x0)
...Verify Failed (and stopped)
...Verify Failed (and stopped)</b>
...Programming failed
MPLAB ICD 2 Ready
<p>
I have MPLAB 6.13, PCM 1.13 and ICD2, which i use over USB.<br>
I checked the connections from and to the 16F877 and they seems to be correct.<br>
Please, can you help me?<p>
Thanks!
Original Post ID: 13675 |
mcafzap
Joined: 07 Sep 2003 Posts: 46 Location: Manchester, UK
| Re: ICD2 cannot program my 16F877 |
Posted: Tue Apr 15, 2003 4:39 am |
:= Verifying...
:= ...Program Memory
:= <b>ICD0161: (CMemory::Verify) Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x3000, Val Read = 0x0)
FWIW I've had similar results from time to time. It seems that the write protection bits become set and hence the 'Val Read = 0x0'. The only solution I've found is to program the processor with an external programmer, then replace it in your development board where it will once again work OK.
Steve
Original Post ID: 13677 |
Posted: Tue Apr 15, 2003 6:54 am |
:=:= Verifying...
:=:= ...Program Memory
:=:= <b>ICD0161: (CMemory::Verify) Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x3000, Val Read = 0x0)
:=FWIW I've had similar results from time to time. It seems that the write protection bits become set and hence the 'Val Read = 0x0'. The only solution I've found is to program the processor with an external programmer, then replace it in your development board where it will once again work OK.
:=Steve
Thanks for your fast reply.
I don't believe that this is the problem, because I tried to program two new and "fresh" PICs. Why should the configuration bits have changed?
If I have no other chance then I will try to get an Pro Mate II. Or does anybody know a cheaper external programmer for 16F877 PICs?
Marcel Tschopp
Original Post ID: 13679 |
jds-pic Guest
Posted: Tue Apr 15, 2003 11:25 pm |
this message usually means one of the following:
1) Vcc is not on, or the ICD2 can't supply enough current
2) the ICD2 <-> PGD/PGC/MCLR connections are miswired
3) other logic on the PGD or PGC pins is causing contention
4) the PGM pin is pulled high
5) you have some other problem related to the electrical config
until that error message is solved, nothing after it should be expected to work in any deterministic way.
jim
Original Post ID: 13697 |
Chip Jansen Guest
Posted: Fri Jun 20, 2003 2:30 pm |
:=> ICDWarn0020: Invalid target device id (expected=0x4D, read=0x0)
:=4) the PGM pin is pulled high
I ran across the same problem with an ICD 2 / 18f720 --
I had stuff wired up to port B and consequently pin B5
which was the PGM pin and the switch happened to be pulled high.
Thank you!
~chip
Original Post ID: 144515435 |
