MAX6675
Post new topic   Reply to topic    CCS Forum Index -> Code Library
ALI_726
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
MAX6675
PostPosted: Wed Aug 15, 2012 4:20 am     Reply with quote
hi i am sending this original code for max6675 Enjoy.....!
just copy and paste this code in to the editor
#include <18F452.h>
#device adc=10
#FUSES NOWDT, WDT128, HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV45, PUT, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#define TC_CLK    PIN_B0
#define TC_CS     PIN_B1
#define TC_DATA   PIN_B2
   int1 thermocouple_error;    //a handy dandy global error flag to
                               //tell you if a thermocouple is connected or not
   int16 data;
   char msg[32];
void init_TC(void)
   output_low(TC_CLK);
   output_low(TC_DATA);
   output_high(TC_CS);            //if we idle high, the chip keeps doing conversions. Change this if you like
int16 read_TC(void)               //It takes 200ms (ish) for the MAX6675 to perform a conversion
   int8 i;
   output_low(TC_CS);            //stop any conversion processes
   for (i=0;i<16;i++){
      output_high(TC_CLK);
      output_low(TC_CLK);
      shift_left(&data,2,input(TC_DATA));      //reads in 2 bytes to data from the pin TC_DATA
   thermocouple_error = bit_test(data,2);      //this is the thermocouple status bit
   output_high(TC_CS);
   return(data);
int16 sortout(int16 raw)
    return(0x0FFF & (raw>>3));      //returns only the bits converning temperature
float toFloat_TC(int16 tmp)
   return((float)tmp/4.0);      //adjusts data to floating point format, and accounts for the decimal point
float do_everything(void)
   init_TC();
   return(toFloat_TC(sortout(read_TC())));
   port_b_pullups(TRUE);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   while(TRUE){
      delay_ms(800);
      sprintf(msg,"%01.2f%cC\r\n",do_everything(),0xB0);
      if(thermocouple_error)
         printf("Thermocouple not connected\r\n");
         printf("%s",msg);
compile this code and Enjoy...!
jruibarroso
View user's profile Send private message Send e-mail MSN Messenger
code for MAX31855
PostPosted: Thu Aug 16, 2012 4:23 am     Reply with quote
Hi, i'm searching long time for code (driver) for MAX31855 that is very like this MAX6675 , can you please design a code to control MAX31855 ?
thank you very much
bkamen
Re: code for MAX31855
PostPosted: Sat Aug 18, 2012 2:45 am     Reply with quote
I don't think you'll find anyone to do your work for you.
Why not just take this driver, modify it as needed and be thankful most of the work was already done for you?
I've written drivers for the 31855... and it's not that hard.
Cheers,
-Ben
p.s. No. I can't give you the code since it was written for a client.
jruibarroso
PostPosted: Fri Aug 24, 2012 9:13 am     Reply with quote
Thank you so much for your reply and I understand your reasons.
My problem is that I don't have enough knowledge to design a driver for this IC, so my "cry for help Very Happy "
Anyway, if you find something may help me, please let me know.
Greetings
bkamen
PostPosted: Fri Aug 24, 2012 9:43 am     Reply with quote
My problem is that I don't have enough knowledge design a driver for this IC, so my "cry for help Very Happy "
That's the joy of learning! I'm assuming you're a student...
If you work at a company, I'm sure there are many here willing to write such a driver for you as a contractor.
ALI_726
PostPosted: Sat Aug 25, 2012 3:26 am     Reply with quote
Greetings
dear don't worrry, I write the code for students and others. Also your code is almost ready, within a few days it will be on forum.
ALI_726
driver for MAX31855
PostPosted: Mon Aug 27, 2012 5:07 am     Reply with quote
Greetings
hello dear this is driver for you.........!
#include <18F452.h>
#device adc=10
#define TC_CLK    PIN_E0
#define TC_CS     PIN_E1
#define TC_DATA   PIN_E2
   int1 thermocouple_error,Short_to_Gnd,Short_to_Vcc,Open_Circuit;
   int32 data;
   char msg[32];
void init_TC(void)
   output_low(TC_CLK);
   output_high(TC_CS);            //if we idle high, the chip keeps                                   //doing conversions. Change this if you like
int32 read_TC(void)
   int8 i;
   for (i=0;i<32;i++){
      output_low(TC_CLK);
      shift_left(&data,4,input(TC_DATA));      //reads in 4 bytes to data from the pin TC_DATA
   thermocouple_error = bit_test(data,16); //this is the thermocouple status bit
   Open_Circuit = bit_test(data,0);       //this is the thermocouple status bit
   Short_to_Gnd = bit_test(data,1);       //this is the thermocouple status bit
   Short_to_Vcc = bit_test(data,2);       //this is the thermocouple status bit
   output_high(TC_CS);
   return(data);
int32 sortout(int32 raw)
    return(0x00003FFF & (raw>>18));      //returns only the bits converning temperature
float toFloat_TC(int32 tmp)
   init_TC();
   setup_adc(ADC_OFF);
   setup_wdt(WDT_OFF);
   while(TRUE){
      delay_ms(800);
      sprintf(msg,"%03.2f%cC\r\n",do_everything(),0xB0);
         if(Open_Circuit)
            printf("Thermocouple not open\r\n");
            if(Short_to_Gnd)
               printf("Thermocouple short to Ground\r\n");
               if(Short_to_Vcc)
                  printf("Thermocouple short to Vcc\r\n");
         printf("%s",msg);
jruibarroso
PostPosted: Mon Sep 03, 2012 6:03 am     Reply with quote
No, I'm not a student, only a self learning person and yes, I work in a company that's mine.
jruibarroso
PostPosted: Tue Sep 04, 2012 5:18 am     Reply with quote
I wrote this code with some changes to show results on a LCD
Now it's all ok but if temperature readings go along 32.768 ÂșC , readings go crazy , seems mcu is dealing with a 16bit variable but data is int32
can you help me one more time ??
Thank you
#include <18F252.h>
#device adc=10
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP
#define TC_CLK    PIN_C6
#define TC_CS     PIN_C5
#define TC_DATA   PIN_C4
#include <Display_2x16 Detector manual CE.c>
#include <lcd_symbols.c>
   int1 thermocouple_error,Short_to_Gnd,Short_to_Vcc,Open_Circuit;     //a handy dandy global error flag to
   int32 data;
 // char msg[32];
void init_TC(void)
   output_low(TC_CLK);
int32 read_TC(void)
   int8 i;
   for (i=0;i<32;i++){
      output_low(TC_CLK);
  // thermocouple_error = bit_test(data,16); //this is the thermocouple status bit
   output_high(TC_CS);
   return(data);
   init_TC();
  // port_b_pullups(TRUE);
   setup_adc(ADC_OFF);
  // setup_psp(PSP_DISABLED);
   setup_wdt(WDT_OFF);
   lcd_init();
   delay_ms(80);
   init_user_chars();
   delay_ms(80);
   while(TRUE){
     // sprintf(msg,"%03.2f%cC",do_everything(),0xB0);
      //if(thermocouple_error) {printf(lcd_putc,"\fThermocouple not connected");DELAY_MS(200);}
      if(Open_Circuit) {printf(lcd_putc,"\fThermocouple open");DELAY_MS(200);}
      if(Short_to_Gnd) {printf(lcd_putc,"\fThermocouple shrt GND");DELAY_MS(200);}
      if(Short_to_Vcc) {Printf(lcd_putc,"\fThermocouple shrt Vcc");DELAY_MS(200);}
         printf(lcd_putc,"\f %5.3w %cC",do_everything(),223);
[/code]
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
