tester
Re: dear tester it is working fine in V4.023 |
Posted: Tue Aug 18, 2009 9:09 am |
mutthunaveen wrote: | it is working fine in V4.023 | Excellent!
mutthunaveen wrote: | Can you give me a study guide to add the functions into RTOS ? | What do you mean? |
mutthunaveen
Joined: 08 Apr 2009 Posts: 100 Location: Chennai, India
thnaks |
Posted: Wed Aug 19, 2009 2:27 am |
actually for programming in CCS we know C commands to write a program
but to write in the RTOS in ccs i have to know how to configure the tasks and run them..... some more simple and difficult example programs.................
i studied the example program but i need some more example programs ![Smile](images/smiles/icon_smile.gif) |
tester
mutthunaveen
thnaks brother |
Posted: Wed Aug 19, 2009 6:00 am |
I will try at my home and i will update to you soon.
My suggestion is to create in the same site where you posted the RTOS..... for different compilers so that many can go through them............ it will be good for beginners like me.
I will update you soon brother. |
tester
tester
Re: OSA - RTOS for PIC controllers |
Posted: Thu Oct 15, 2009 10:39 am |
Holger wrote: | Hello,
What is the advantage to use OSA instead of the built-in in RTOS from CCS?
thanx Holger |
Actually, I did not work with CCS RTOS, so I can't compare these OSes rather competently. But in two word:
Advantages:
1. OSA requires less RAM and ROM.
2. In OSA task may have a priority. When there are several ready to work tasks, scheduler gives control to most priority task.
3. OSA have more services and system objects. The are:
- Binary semaphores
- Counting semaphores (present in CCS RTOS)
- Simple byte messages (present in CCS RTOS)
- Pointers to messages
- Queues of simple messages (present in CCS RTOS)
- Queues of message pointers
- User timers
- Flags
- Critical sections
4. In OSA task can wait an event with timeout breaking
5. OSA doesn't need any PIC's peripherals for itself purposes (CCS RTOS needs a timer)
6. OSA is rather well documented. (As I think )
Disadvantages:
1. OSA doesn't support 12-bit and 16-bit controller under CCS compiler.
2. Firstly OSA was adapted for HTPICC compilers, so several solutions for CCS compiler are not optimal.
3. Too little people works with OSA, so I haven't enough bug reports to improve it (or to fix bugs if they are present)
(I did not test speed characteristics because these two OSes are rather different.)
I think you should try both RTOSes to choose your favorite.
Last version.
Documentation.
Good luck! |
mickey231bhq
Posted: Mon Jan 04, 2010 3:34 pm |
Hello tester
I am currently using CCS 4.104 version, OSA RTOS can not seem to work properly on this version.
In the osa_ccs18.c:
_OS_SET_FSR_CUR_TASK ();
_OS_SET_FSR_CUR_TASK_W (OS_CODE_POINTER_SIZE);
_OS_CurTask-> Timer = Delay;
ERROR: Previous identifier must be a pointer
In the osa.c:
if (! Task-> State.bEnable)
Task-> pTaskPointer = TaskAddr;
Task-> Timer = 0;
* ((OS_TASKS_BANK char *) & Task-> State) = priority;
other:
OS_Run ();
Able to solve the problem? |
tester
Posted: Tue Jan 05, 2010 2:16 am |
mickey231bhq wrote: | Hello tester
Hello, Mickey! Thank's for the report, I'll try check it as soon as possible (within a couple of days) and give you a solution. |
tester
Posted: Tue Jan 05, 2010 11:03 am |
mickey231bhq wrote: | Able to solve the problem? |
Hello again!
Just now I have installed demo version 4.102 (there is no 4.104 demo). It supports PIC18F458 only. The example from OSA\EXAMPLES\CCS\lights_cc18.mcp was compiled with no errors (I only changed chip include file to "#include <18F458.h>" at the begin of file).
What OSA version do you use?
What chip?
Did you create you project correctly?
If you did, then please describe a problem more detailed (show me a texts of program, content of osacfg.h file). |
mickey231bhq
Posted: Tue Jan 05, 2010 12:41 pm |
I use the example of you, lights_ccs18 project files, the same problem.
osa version: osa_91219.zip
ccs version: v4.104
chip: pic18f258
Are as follows:
Code: | Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\PICC\Ccsc.exe" +FH "lights_ccs18.c" I+="C:\osa\example\ccs;c:\osa" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 66 "c:\osa\port\osa_ccs18.c" Line 86(27,28): Previous identifier must be a pointer
*** Error 66 "c:\osa\port\osa_ccs18.c" Line 109(49,50): Previous identifier must be a pointer
*** Error 66 "c:\osa\port\osa_ccs18.c" Line 212(49,50): Previous identifier must be a pointer
*** Error 66 "c:\osa\port\osa_ccs18.c" Line 419(27,28): Previous identifier must be a pointer
*** Error 66 "c:\osa\port\osa_ccs18.c" Line 428(28,33): Previous identifier must be a pointer
*** Error 66 "c:\osa\port\osa_ccs18.c" Line 432(31,32): Previous identifier must be a pointer
*** Error 66 "c:\osa\port\osa_ccs18.c" Line 673(31,32): Previous identifier must be a pointer
*** Error 66 "c:\osa\osa.c" Line 1076(24,29): Previous identifier must be a pointer
*** Error 66 "c:\osa\osa.c" Line 1081(36,48): Previous identifier must be a pointer
*** Error 66 "c:\osa\osa.c" Line 1085(33,38): Previous identifier must be a pointer
*** Error 66 "c:\osa\osa.c" Line 1092(47,52): Previous identifier must be a pointer
*** Error 66 "lights_ccs18.c" Line 182(13,14): Previous identifier must be a pointer
13 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Wed Jan 06 02:16:29 2010 |
Last edited by mickey231bhq on Wed Jan 06, 2010 12:23 am; edited 1 time in total |
future
Posted: Tue Jan 05, 2010 4:58 pm |
compiler version? |
tester
Posted: Wed Jan 06, 2010 5:29 am |
mickey231bhq wrote: | I use the example of you, lights_ccs18 project files, the same problem.
ccs version: v4.104
chip: pic18f258
Are as follows:
Clean: Done.
Unfortunately, I can't check it at v4.104. But all pointed by the compiler lines are written by all C-rules, they contain no errors. Are you sure you did not modify OSA sources? Compiler gives errors on access to _OS_CurTask variable. It should be defined in osa.c:
OST_TASK_POINTER NEAR _OS_CurTask __osa30_near; // Pointer to current task
Where type OST_TASK_POINTER is defined as:
typedef OS_TASKS_BANK OST_TCB * OST_TASK_POINTER;
in osa.h file. Thus variable _OS_CurTask is defined as a pointer.
(definitions NEAR, __osa30_near, OS_TASK_BANK are empty for CCS compiler)
Try to download OSA again, or try some previous versions. |
tester
Posted: Wed Jan 06, 2010 6:12 am |
My friend just now checked OSA with new 4.104 version and he confirmed these errors. OSA really does not compile under 4.104. I will work on this problem and try to solve it as soon as possible.
Thank's for bug report again. |
tester
DerWolf
Bug Fixed? |
Posted: Sat Jan 30, 2010 1:52 pm |
I just wanted to start trying OSA and have read about this problem. Is this bug fixed again, as I just bought the new ccs Compiler?
Thanx |
