I am using #if defined TypeA or #if defined TypeB throughout my code depending on which of two product types will be connected.
#if defined(__TYPE_A__)
///code here
#endif
#if defined(__TYPE_B__)
///code here
#endif
This works very well but requires setting TYPE_A or TYPB_B when compiling. I am now looking to be able to switch the type via an rs232 command and wanted to know if I can re-define the system to say type_B from within the code.
Is it possible to just run the command
#define __STYPE_B__
Chris.......
Posted: Thu Jun 18, 2009 11:48 am
The #if statements work at compile-time.
Apparently you want something that works at run-time. One method
would be have an eeprom address set to a certain value. Then you
could read the eeprom address at start-up, and load it into a RAM
variable. Then test that RAM variable at suitable points in your program
with if() statements to control program flow.
