Programming from PCWHD 4 using PICKIT2
falex
PostPosted: Thu Jun 18, 2009 3:01 am     Reply with quote
I am trying to program my 18F4550 from PCWHD 4 using PICKIT2, but it doesn't work. I can program it from MPLAB using PICKIT2, but I want to do it from PCWHD. I have tried to add an entry in User Defined Tools, like this: Compile > Program Menu : "D:\Electronica\Compilatoare\PK2CMDv1-20\pk2cmd.exe" /P%D /F%H /M , the entry apears on Compile tab > Program chip > PICKIT2 but it is grayed out.
How can I use my PICKIT2 to program my uC from PCWHD.
Thank you.
bungee-
PostPosted: Thu Jun 18, 2009 3:19 am     Reply with quote
I'm using PiCKIT2 and I use program that comes with it to program the PIC-s.
Program sicks with the supplied HEX name so when you press program button it takes new HEX and programs it to PIC.
falex
PostPosted: Thu Jun 18, 2009 8:06 am     Reply with quote
Thank you for your answer. Can you please be more specific about what program are you using and how you integrated it with PCWHD. My PICKIT2 is home made, so I don't know you program you refer to.
Thank you.
bungee-
PostPosted: Thu Jun 18, 2009 5:24 pm     Reply with quote
Sorry I forgot to write that it is not integrated with PCWHD, but that is not a problem, because you do not need to open the hex everytime, once if enough.
I use microchip's application: PICkit 2 V2.61 Install
On the same page, that I found this application is also "PK2CMD V1.20 PICkit 2 Command Line Interface" maybe this could be integrated into pcwhd ;)
Link to Microchip product page: PicKit2
