interface of rtc ht1380 with pic16f72
bharatwalia
PostPosted: Thu Jun 18, 2009 12:14 pm     Reply with quote
How to interface a RTC "ht1380" with pic16f72. Its a 8-PIN IC.
http://www.holtek.com.tw/pdf/consumer/1380_1v111.pdf
Pad Description
Pad No. Pad Name I/O
Internal
Connection
Description
1 X1 I CMOS 32768Hz crystal input pad
2 X2 O CMOS Oscillator output pad
3 VSS  CMOS Negative power supply, ground
4 REST I CMOS Reset pin with serial transmission
5 I/O I/O CMOS Data input/output pin with serial transmission
6 SCLK I CMOS Serial clock pulse pin with serial transmission
7 VDD  CMOS Positive power supply
PostPosted: Thu Jun 18, 2009 1:27 pm     Reply with quote
The Holtek HT1380 is similar to the DS1302. CCS has a driver for
the DS1302:
c:\program files\picc\drivers\ds1302.c
You can compare the data sheets and modify the ds1302 driver to
make a ht1380.c driver.
asmboy
what the heck is the protocol here ?
PostPosted: Thu Jun 18, 2009 3:07 pm     Reply with quote
is there a NAME for the goofy physical layer protocol these parts use ?
on first blush,
it it looks like vanilla SPI - but with a shared SDO/SDI line
is there a name for that ?
PostPosted: Thu Jun 18, 2009 4:28 pm     Reply with quote
Yes, it's called "3-wire" SPI.
http://en.wikipedia.org/wiki/Serial_Peripheral_Interface_Bus#3-Wire_Serial_Buses
