I have some troubles with storing data into the EEprom of a 12F675
CCloader does not accept the following instruction:
#rom 0xf2100={0x85}
According the CCloader File Info the file is CORRUPT.
Adress F2100 is out of range.
Other programmers don't have any problem with the Eeprom data table.
When I remove the #rom command I can program the controller without any problem.
What can I do?
You can try it by just adding the following command to your code
#rom 0xf2100={0x85}
Best regards,
Bas
Posted: Mon May 25, 2009 2:02 pm
#rom 0xf2100={0x85}
