abq_guy
LST file registers for USART |
Posted: Wed Apr 15, 2009 10:13 am |
#use rs232 (baud=850000, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8, BRGH1OK, STREAM=COM_A) //compiles OK
I am setting the baud rate to 850000 bps, and the compiler generates the following LST file.
015E: BTFSS F9E.4
0160: BRA 015E
0162: MOVWF FAD
0164: RETLW 00
How do I infer what is in the BRG16 and BRGH and the SYNC bit is being set to from the LST file ? The LST file is refereing to location FAD, which is the TXREG1 register.
I am lost, Please help. Also If I want to set these registers myself, how can I do it ?
Thanks,
abq_guy |
Posted: Wed Apr 15, 2009 10:23 am |
Set the list file format to "Symbolic" mode. Look in the Project / Build
Options menu for this setting. Then the names of the registers will
appear in the .LST file instead of their addresses. |
Posted: Wed Apr 15, 2009 10:25 am |
The part of the list file you show here is for transmitting the data, not for configuring the UART. The code for configuring the UART is most likely at the start of main().
Quote: | If I want to set these registers myself, how can I do it ? | set_uart_speed() |
abq_guy
Posted: Wed Apr 15, 2009 10:43 am |
Thanks PCM_programmer. That worked. I can see the register names now.
Thanks Ckielstra. Is there a baud rate limit on the set_uart_speed(). The manual mentions it is 115kbps.
Thanks,
abq_guy |
Posted: Wed Apr 15, 2009 3:04 pm |
You can go well over 115K, _but_ you run into the limitations on the available divisors, and clock rates. The 115K limit, was applicable to older compilers, but I have run 'unusual' rates, like 500K, with a chip at 40Mhz, fine. 850000, is probably going to actually be giving perhaps 833333Hz. Basing this on a likely master clock of 40Mhz, then the clock feeding the BRG, will be 10Mhz, and this /12, gives the closest match to 850K. This is 2% in error, which the compiler will accept (it'll warn if the rate is badly wrong). You would actually be 'better' at something like 34MHz master clock for this rate. However, with a byte time of just under 12uSec, you are going to have to be _very_ careful with your code. No interrupt handling, and if data is arriving 'unheralded', a very tight wait loop will be needed.....
