Single step debug not working when PLL running
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
sjones
PostPosted: Mon Feb 16, 2009 8:51 am     Reply with quote
I am using a PIC18F66J50. It is running from a 4MHz external crystal and after boot up I enable the 48MHz PLL and then run from that with no problem. However if I try and single step after the PLL has started the pic crashes and the program counter goes to $FFFF. The debugger seems to thinks the MCU is always running at 4MHz (Measured on reset?)
eskimobob
PostPosted: Mon Feb 16, 2009 1:14 pm     Reply with quote
I've seen strange behaviour like this recently too and as it happens, I was using the PLL (different PIC though).
I was able to find the problem without the debugger fortunately so I did not investigate the cause too closely.
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
