Byte to Nibble
BoydNielsen
Byte to Nibble
PostPosted: Sun Oct 05, 2008 4:08 pm     Reply with quote
Does anyone have a quick and efficient way of converting a byte into two separate nibbles in CCS? Years ago on a different platform, we used to be able to:
int8 a, MSnibble, LSnibble;
a = 174;                  // arbitrary number
MSnibble = a / 16;        // 'MSnibble' is the upper nibble
LSnibble = a mod 16;      // 'mod' for modulus
                          // 'LSnibble' is the lower nibble
However, this does not seem to work in CCS. A code snipet would be extremely helpful.
Boyd
PostPosted: Sun Oct 05, 2008 4:21 pm     Reply with quote
Look at the lcd_send_byte() function in the CCS lcd.c driver.
It passes nibbles to another function and it shows how to do it.
BoydNielsen
PostPosted: Sun Oct 05, 2008 4:33 pm     Reply with quote
Thanks. Sometimes one forgets the basics (shift right and bit masking)!
a = 174;
MSnibble = a >> 4;     // right shift to remove lower nibble
LSnibble = a & 0xF;    // bit mask to remove upper nibble
Boyd
PostPosted: Mon Oct 06, 2008 3:12 am     Reply with quote
As a comment, the original would have worked, if you had used the C modulus function (%, not 'mod'). Shifts are much quicker though. However the compiler is 'smart' enough, to perform division by 16, using shifts, so it would not make too much difference. Smile
