Problem with HIGH Interrupts
galatar
PostPosted: Thu Oct 02, 2008 2:09 am     Reply with quote
My code was working fine till I place next lines for HIGH interrupt on EXT1.
Previously my code starts like that:
#include <18F8722.h>
#device adc=10
#device *=16
#rom int8 0xf003F8={0x01}
And everything was o.k. But when I place the lines below:
#device adc=10
#device *=16
#device HIGH_INTS=true
#int_EXT1 HIGH
the compiler gives me the next errors:
*** Error 81 "C:\...\device.h" Line 19(6,7): Expecting a basic type
*** Error 43 "C:\...\device.h" Line 19(11,19): Expecting a declaration
*** Error 43 "C:\...\device.h" Line 19(19,20): Expecting a declaration
*** Error 43 "C:\...\device.h" Line 19(20,21): Expecting a declaration
*** Error 43 "C:\...\device.h" Line 19(21,25): Expecting a declaration
*** Error 43 "C:\...\device.h" Line 19(25,26): Expecting a declaration
Line 19 is:
Can someone tell me what happens? Thanks in advance!
PostPosted: Thu Oct 02, 2008 2:32 am     Reply with quote
You need to place the interrupt handler routine, immediately after the line declaring the interrupt. The next 'instruction block', becomes the interrupt handler. Your next instruction block, is the #rom statement, not a function, hence won't work...
So:
#device adc=10
#device *=16
#INT_EXT1 HIGH
void handler_for_ext1(void) {
    //Code here for the interrupt handler
n-squared
Hi
You need to put the #int_EXT1 HIGH line just above the interrupt function itself.
Your sample code does not show enough detail to see the problem.
BR
Every solution has a problem.
PostPosted: Thu Oct 02, 2008 3:08 am     Reply with quote
Thanks to Ttelmah and n-squared. Thank you very much! I
and now everything is o.k.
#device adc=10
#device *=16
#int_EXT1 HIGH
void read_isr()
Thanks!
meereck
PostPosted: Thu Oct 02, 2008 3:10 am     Reply with quote
it should be also noted that if you define
and you dont specify any interrupt to be "HIGH" (e.g.)
#INT_EXT1 HIGH
, the PIC might behave weird.
That is what I found out. I posted that issue at this forum few months ago.
M.
csanders
PostPosted: Tue Oct 14, 2008 4:18 pm     Reply with quote
Is it possible to have more than 1 ISR marked as 'HIGH'?
PostPosted: Wed Oct 15, 2008 2:35 am     Reply with quote
Yes.
The behaviour of the system is fairly complex, but 'here goes'. There are two words that trigger moving the interrupt to the high priority vector, 'HIGH', and 'FAST'. When 'HIGH' is used, the compiler creates exactly the same code, as is used for the low priority handler. It automatically adds data saving code, tests for multiple interrupts if used, and jumps to the right handler. In fact on most chips this will _always_ happen, if you select as a 'HIGH' interrupt any interrupt other than INT_EXT, and then use INT_EXT as well, without adding the flag. If you look at the data sheet, there is no interrupt priority bit for INT_EXT, and if priorities are enabled, this interrupt always becomes a high priority source. This is very much a 'caveat' of the PIC. The compiler will handle this, automatically adding the test for this interrupt to the high priority code, even though it is not flagged as 'HIGH' by you.
If you instead use 'FAST', the compiler flags the selected interrupt as a high priority one, but does not add any data saving code, or tests for other interrupts. You can in fact use this as an alternative for 'INT_GLOBAL', with high priority interrupts. What you do, is flag one interrupt as 'FAST', and have it's handler save the minimum number of registers, then if necessary test for any other interrupts being triggered. All you then do is set the high priority bit, on any other interrupt you want as high priority, and this one handler will be called for all the interrupts. However remember to check for INT_EXT, if using this route.
The automatic behaviour of the chip, in making INT_EXT high priority, if priorities are enabled, is the core reason for problems if you set 'HIGH_INTS=true', and then don't use any interrupts as high priority. The compiler only adds the handler code, once one interrupt is flagged as 'HIGH' but as soon as the priorities are enabled, INT_EXT, will be vectoring to the high priority handler. Since there is no handler present, disaster....
