RA8835 driver
Goto page Previous  1, 2, 3  Next
PostPosted: Thu Jun 05, 2008 10:56 am     Reply with quote
There's a bug in this function in sed1335.c in vs. 4.073. I just found it.
The expression shown in bold is wrong. It's adding 1 to the address
before it's cast to an int8 pointer. That's wrong. It should be cast to
an int8* before the 1 is added to it. This bug probably doesn't affect
you though. I don't think you call this routine.
int16 getCursorAddress()
int16 addr;
glcd_sendCMD(GLCD_CMD_GET_CSR_ADDR);
TGLCD_DATA
*(int8*)(&addr ) = glcd_readByte(); // Read low part
*(int8*)(&addr + 1) = glcd_readByte(); // Read high part
return addr;
It should be changed to this.
*((int8*)&addr + 1) = glcd_readByte();
Actually, I rediscovered it. I had found it before, in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=32684&start=25
I don't know if it was reported back then, but I'm going to report it now.
murtis
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Thu Jun 05, 2008 4:56 pm     Reply with quote
I looked to driver code SED1335.c. However, i did not find anything about calling this routine. So, the bug doesn't affect me....
MurtiS
murtis
PostPosted: Fri Jun 06, 2008 12:16 am     Reply with quote
I tried you said, But, no change on the GLCD screen. I will try to find any error, but i do not know how i can.
MurtiS
PostPosted: Fri Jun 06, 2008 1:15 pm     Reply with quote
The problem could be one of these:
1. A bug in the SED1335.c driver.
2. A bug in the Graphics.c driver.
3. A bug in your compiler version.
4. A bug in your code that calls the drivers.
5. The SED1335 and RA8835 may not be completely compatible, either
in terms of software and/or hardware timing.
6. You may have connected the Winstar LCD incorrectly to your PIC.
7. Your individual unit of the Winstar LCD may have a problem in it.
8. A particular batch of the Winstar LCDs may have bugs.
9. Your individual PIC may be flaky.
10. Your board may have power supply problems such as droop or noise.
murtis
PostPosted: Sat Jun 07, 2008 8:10 am     Reply with quote
to 1: Perhaps. I am searching whether there are any bugs or not
to 2: Perhaps. I am searching whether there are any bugs or not
to 3: I searched for bug. But, i did not find anything
to 4: There is no bug in my code that calls the drivers
to 5: The SED1335 and RA8835 completely compatible in according to Hardware. Perhaps, there can't be compability as sofware.
to 6: There is no problem. Because i have more than one. I tried the other ones.
to 7: There is no problem. Because i have more than one. I tried the other ones.
to 8: I do not know.
to 9: There is no problem. Because i have more than one. I tried the other ones.
to 10: these got controlled.
However, i will inform you when something can be good things. If you have some idea, i want to know your idea or some development
MurtiS
murtis
I think....
PostPosted: Wed Jun 11, 2008 5:09 am     Reply with quote
I think that there are any problems such as droop or noise or timing speed_?
MurtiS
murtis
PostPosted: Thu Jun 12, 2008 11:57 pm     Reply with quote
There is no noise or timing speed... I could not find any error or bug, for now....
MurtiS
Lykos1986
PostPosted: Fri Jun 20, 2008 2:19 am     Reply with quote
Have you found any solution to your problem? I have exactly the same problem, but I am using a regular SED1335 driver!
murtis
PostPosted: Fri Jun 20, 2008 4:33 am     Reply with quote
I have not yet any solution. But, i try to find the problem... If you have a solution or any idea, can you share with me_?
MurtiS
murtis
PostPosted: Fri Jun 20, 2008 6:44 pm     Reply with quote
Absolutely, SED1335 is not fully compatible with RA8835 controller in according to software. If you see the regular driver code for SED1335, we can see the reading problem. So, interesting character or some dot goes on the GLCD Screen. But, there is no idea which line has error....
MurtiS
murtis
PostPosted: Mon Jun 23, 2008 2:37 am     Reply with quote
Do you have any idea_? The problem is going on.
MurtiS
murtis
PostPosted: Sat Jun 28, 2008 4:40 pm     Reply with quote
If you call the this header that is below:
void glcd_pixel(int16 x, int16 y, int1 color)
   int8  data;
   int16 addr;
   // Calculate the byte address containing the pixel
   addr = GLCD_GRAPHICS_ADDR + (GLCD_WIDTH/8 * y + x/8);
   // Read the byte of data at the address
   data = getData(addr);
   // Turn the pixel on or off
   if(color == ON)
      bit_set(data, 7 - x%8);
      bit_clear(data, 7 - x%8);
   // Write the new data byte to display memory
   setData(addr, data);
error is on the line
while the reading byte must be 0b00000000, the reading byte is 0b01000000. I tried to find how the reading byte is changing but this is very hard
MurtiS
thiru_electrifiers
is this thread still alive ?
PostPosted: Mon Jul 14, 2008 7:39 am     Reply with quote
hi,
i too face the same problem..
the display read command always returns a corrupted data...
murtis
PostPosted: Thu Jul 17, 2008 8:37 am     Reply with quote
I have no time for trying another solution now. If we have a solution for this, i will send here...
MurtiS
murtis
solution1:
PostPosted: Tue Jul 29, 2008 8:45 am     Reply with quote
Error is on the line below:
We can solve this problem, but we need the 9Kb on the memory. If we can use the memory of the microcontroller in according to memory of the GLCD, this problem will be solved this problem by this way.
I do not know solution for now Smile
MurtiS
Page 2 of 3
