Overdrive Touch Driver for Maxim/Dallas iButtons
herselmann
PostPosted: Sat May 31, 2008 12:02 pm     Reply with quote
   Title:                1-Wire Overdrive Speed Driver
   Author:               Rudolph Herselman
   Orig File Name:       Overdrive_Touch.c
   Date:                 29 December 2007
   Version:              1.0
   Target MCU:           PIC family
   Description:          Driver for the Dallas/Maxim range of 1-Wire devices,
                         capable of operating at normal and overdrive speed
   Requirments:          Clock freq fast enough to generate a delay of
                         LESS than 0.85us (see note "Overdrive Speed" below)
   Change Log:
   Version     Date         Editor            Details
    1.0       29/12/07      R.Herselman       Initial release
   Notes:
   This driver is provided as is, and no warranty is given that it is bug free
   and I will not be held liable for any damages caused directly or indirectly
   whilst using this driver.
   Consult the app note for any copyrights pertaining to the use of this code
   in commercial products.
   Below are the defines used for the various time delays used in
   the Maxim/Dallas 1-Wire protocol. For more information on the time
   delays consult APPLICATION NOTE 126, "1-Wire Communication Through Software"
   The ABC's used in the defines corrosponds to the ABC's used in the appnote,
   refer to appnote for detailed explanation of their meaning.
   Standard Speed:
   The standard speed uses a normal "delay_us(x)" function (where x is one of the
   A0-J0 defines).
   Overdrive Speed:
   The overdrive speed uses a "delay_cycles(x)" function (where x is one of the
   A1-J1 defines) because the delays are very short. Thus the values need to be
   adjusted acording to the clock freq of the micro.
   As an example:
   A 16F877 running at 20Mhz will have a cycle of (1/((20e6)/4)) = 0.2us
   To get a delay of 7.5us we delay the micro for (7.5/0.2) cycles ~ 38,
   This will yield a daley of: 38*0.2 = 7.6us
   Driver has been tested on various iButtons and seems to work fine, I have not
   done any real speed tests to determine the exact speed but there is definetly
   an improvement in data transfer, anyone wishing to conduct such tests and post
   their results are welcome.
   Schematic:
                                   Vcc
                                    /     <---- Pullup resistor 4K7,
                                    \           refer to datasheet/app
                                    /           notes for alternate values
   iButton touches here-->   )------o---------> Any IO pin on micro
   and on GND connection                        Remember to change the
                                                #define for the touch_pin
#ifndef Touch_pin
#define Touch_Pin pin_XX      //Define your touch pin here
//************ Standard Speed ******************
//         Current (us)           Range(us)
//                           Min   Rec   Max
#Define      A0   6       // 5     5     15
#Define      B0   64      // 59    64    N/A
#Define      C0   60      // 60    60    120
#Define      D0   10      // 8     10    N/A
#Define      E0   9       // 5     9     12
#Define      F0   55      // 50    55    N/A
#Define      G0   0       // 0     0     0
#Define      H0   480     // 480   480   640
#Define      I0   70      // 63    70    78
#Define      J0   410     // 410   410   N/A
//****************** Overdrive Speed ******************
//      Current (cycles)       Range(us)       Curent(us) @ 20MHz
//                         Min   Rec   Max
#Define      A1   7      // 1     1.5   1.85        1.4
#Define      B1   38     // 7.5   7.5   N/A         7.6
#Define      C1   38     // 7     7.5   14          7.6
#Define      D1   13     // 2.5   2.5   N/A         2.6
#Define      E1   3      // 0.5   0.75  0.85        0.6
#Define      F1   35     // 6.75  7     N/A         7
#Define      G1   13     // 2.5   2.5   N/A         2.6
#Define      H1   350    // 68    70    80          70
#Define      I1   42     // 7.2   8.5   8.8         8.4
#Define      J1   200    // 39.5  40    N/A         40
Boolean OverDrive=False;   // Global variable used to indicate overdrive status
                           // Overdrive = 0 -> Normal, Overdrive = 1 -> Fast
//Function issues a reset pulse and returns TRUE if device is present
Boolean Touch_Present()
   Boolean Present;
   if (OverDrive)
      delay_cycles(G1);
      output_low(Touch_Pin);
      delay_cycles(H1);
      output_float(TOUCH_PIN);
      delay_cycles(I1);
      present=!input(TOUCH_PIN);
      delay_cycles(J1);
      delay_us(G0);
      delay_us(H0);
      delay_us(I0);
      delay_us(J0);
   if(present)
      return(TRUE);
      return(FALSE);
//Function writes a byte of data to the device, auto changes speed
void touch_write_byte(BYTE data)
   BYTE i;
   if(OverDrive)
      for(i=1;i<=8;++i)
         if (shift_right(&data,1,0))
            Delay_cycles(A1);
            output_float(Touch_Pin);
            Delay_cycles(B1);
            Delay_cycles(C1);
            Delay_cycles(D1);
      for(i=1;i<=8;++i)
            Delay_us(A0);
            Delay_us(B0);
            Delay_us(C0);
            Delay_us(D0);
//Function reads a byte of data from the device, auto changes speed
BYTE touch_read_byte()
   BYTE i,data;
   if(OverDrive)
      for(i=1;i<=8;++i)
        output_low(TOUCH_PIN);
        delay_cycles(A1);
        delay_cycles(E1);
        shift_right(&data,1,input(TOUCH_PIN));
        delay_cycles(F1);
      for(i=1;i<=8;++i)
        delay_us(A0);
        delay_us(E0);
        delay_us(F0);
   return(data);
//Function issues a reset command, then if device is present it issues a
//Overdrive Skip ROM command [0x3C] it then checks to see if device is still
//present. So instead of calling Touch_Present() just call OverDrive_Present() it
//will do the same thing but will also automatically change the speed if needed.
Boolean OverDrive_Present()
   OverDrive = 0;
   if (!Touch_Present())
      return(False);
   touch_write_byte(0x3C);
   OverDrive = 1;
      overdrive = 0;
   return (Touch_Present());
//Function issues a reset command appropriate for the speed used
void touch_reset()
   if (OverDrive)
      delay_cycles(G1);
      delay_cycles(H1);
      delay_cycles(I1);
      delay_cycles(J1);
      delay_us(G0);
      delay_us(H0);
      delay_us(I0);
      delay_us(J0);
There are only 10 kinds of people, those who understand binary and those who don't.
