Joined: 24 Dec 2007 Posts: 2 Location: Pittsburgh PA area
compile and program in one step?
Posted: Sat Apr 26, 2008 6:37 pm
Does anyone know if it is possible to compile and Program Chip (ICD) in the same step (one hotkey)?
In MPLAB, there is a setting that allows the target to be programmed after a successful build and I am looking for the same functionality in the CCS IDE.
now I hit the F9, wait, and hit the F12 (that I have assigned to ICD).
would be convenient to build and go in one step!
thanks!
Ken Johnson
Joined: 23 Mar 2006 Posts: 197 Location: Lewisburg, WV
Posted: Fri May 23, 2008 11:20 am
Jeffrey, I do this all the time. After the 1st compile (after starting the ide), I open the debugger. The top line in the "Debug Configure" window gives you the option of "Compile Reload (TRUE/FALSE). Once set to TRUE, subsequent compiles automatically reload.
I'm a little late here - just saw your post. Hope this helps.
