bwhiten
| LC7981.C Modified LCD Version from CCS code |
Posted: Thu May 29, 2008 9:52 am |
This also has some extra functions for using the built-in character map that I found useful. I have a #ORG in there to put the ascii map into ROM to save RAM.
| Code: | /////////////////////////////////////////////////////////////////////////
//// LC7981.C ////
//// This file contains drivers for using a Crystalfontz CFAG16080A with ///
//// an LED backlight. The CFAG16080A is 160 pixles across and 80 ////
//// pixels down. The driver treats the upper left pixel as (0,0). ////
//// LCD Pin connections: ////
//// (These can be changed as needed in the following defines). ////
//// * 1: VSS is connected to GND ////
//// * 2: VDD is connected to +5V ////
//// * 3: V0 - LCD operating voltage is connected ..................////
//// * 4: R/S - Data or Instruction is connected to C5 ////
//// * 5: R/W - Read or Write is connected to C6 ////
//// * 6: Enable is connected to C7 ////
//// *7-14: Data Bus 0 to 7 is connected to port d ////
//// *15: Chip Select is connected to E0 ////
//// *16: Display Off is connected to E1 ////
//// *17: Reset is connected to E2 ////
//// *18: Negative voltage is also connected .......................////
//// *19: Positive voltage for LED backlight is connected to +5V ////
//// *20: Negavtive voltage for LED backlight is connected .........////
//// glcd_init(mode) ////
//// * Must be called before any other function. ////
//// - mode can be ON or OFF to turn the LCD on or off ////
//// glcd_pixel(x,y,color) ////
//// * Sets the pixel to the given color. ////
//// - color can be ON or OFF ////
//// glcd_line(x1,y1,x2,y2,color) ////
//// * Draws a line from the first point to the second point ////
//// with the given color. ////
//// glcd_rect(x1,y1,x2,y2,fill,color) ////
//// * Draws a rectangle with upper left point (x1,y1) and lower ////
//// right point (x2,y2). ////
//// - fill can be YES or NO ////
//// glcd_bar(x1,y1,x2,y2,width,color) ////
//// * Draws a bar (wide line) from the first point to the ////
//// second point. ////
//// - width is the number of pixels wide ////
//// - color is ON or OFF ////
//// glcd_circle(x,y,radius,fill,color) ////
//// * Draws a circle with center at (x,y) ////
//// glcd_text57(x,y,textptr,size,color) ////
//// * Write the null terminated text pointed to by textptr with ////
//// the upper left coordinate of the first character at (x,y).////
//// Characters are 5 pixels wide and 7 pixels tall. ////
//// - size is an integer that scales the size of the text ////
//// * Note - The given text is character wrapped. If this ////
//// function is used on a different size display, then change ////
//// the GLCD_WIDTH define appropriately. ////
//// glcd_fillScreen(color) ////
//// * Fills the entire LCD with the given color. ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
#ORG 0x1000
const int8 TEXT[51][5] ={0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
0x00, 0x00, 0x5F, 0x00, 0x00, // !
0x00, 0x03, 0x00, 0x03, 0x00, // "
0x14, 0x3E, 0x14, 0x3E, 0x14, // #
0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
0x43, 0x33, 0x08, 0x66, 0x61, // %
0x36, 0x49, 0x55, 0x22, 0x50, // &
0x00, 0x05, 0x03, 0x00, 0x00, // '
0x00, 0x1C, 0x22, 0x41, 0x00, // (
0x00, 0x41, 0x22, 0x1C, 0x00, // )
0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x50, 0x30, 0x00, 0x00, // ,
0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x60, 0x60, 0x00, 0x00, // .
0x20, 0x10, 0x08, 0x04, 0x02, // /
0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x04, 0x02, 0x7F, 0x00, 0x00, // 1
0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x22, 0x41, 0x49, 0x49, 0x36, // 3
0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x3E, 0x49, 0x49, 0x49, 0x32, // 6
0x01, 0x01, 0x71, 0x09, 0x07, // 7
0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x26, 0x49, 0x49, 0x49, 0x3E, // 9
0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x56, 0x36, 0x00, 0x00, // ;
0x08, 0x14, 0x22, 0x41, 0x00, // <
0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x41, 0x22, 0x14, 0x08, // >
0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x3E, 0x41, 0x59, 0x55, 0x5E, // @
0x7E, 0x09, 0x09, 0x09, 0x7E, // A
0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x7F, 0x41, 0x41, 0x41, 0x3E, // D
0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x3E, 0x41, 0x41, 0x49, 0x3A, // G
0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x30, 0x40, 0x40, 0x40, 0x3F, // J
0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x7F, 0x02, 0x04, 0x08, 0x7F, // N
0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
0x7F, 0x09, 0x09, 0x09, 0x76};// R
#ORG 0x1000
const int8 TEXT2[44][5]={0x26, 0x49, 0x49, 0x49, 0x32, // S
0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x7F, 0x20, 0x10, 0x20, 0x7F, // W
0x41, 0x22, 0x1C, 0x22, 0x41, // X
0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x7F, 0x41, 0x00, 0x00, // [
0x02, 0x04, 0x08, 0x10, 0x20, // \
0x00, 0x00, 0x41, 0x7F, 0x00, // ]
0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x01, 0x02, 0x04, 0x00, // `
0x20, 0x54, 0x54, 0x54, 0x78, // a
0x7F, 0x44, 0x44, 0x44, 0x38, // b
0x38, 0x44, 0x44, 0x44, 0x44, // c
0x38, 0x44, 0x44, 0x44, 0x7F, // d
0x38, 0x54, 0x54, 0x54, 0x18, // e
0x04, 0x04, 0x7E, 0x05, 0x05, // f
0x08, 0x54, 0x54, 0x54, 0x3C, // g
0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x20, 0x40, 0x44, 0x3D, 0x00, // j
0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x7C, 0x04, 0x78, 0x04, 0x78, // m
0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x38, 0x44, 0x44, 0x44, 0x38, // o
0x7C, 0x14, 0x14, 0x14, 0x08, // p
0x08, 0x14, 0x14, 0x14, 0x7C, // q
0x00, 0x7C, 0x08, 0x04, 0x04, // r
0x48, 0x54, 0x54, 0x54, 0x20, // s
0x04, 0x04, 0x3F, 0x44, 0x44, // t
0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x44, 0x28, 0x10, 0x28, 0x44, // x
0x0C, 0x50, 0x50, 0x50, 0x3C, // y
0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x00, 0x08, 0x36, 0x41, 0x41, // {
0x00, 0x00, 0x7F, 0x00, 0x00, // |
0x41, 0x41, 0x36, 0x08, 0x00, // }
0x02, 0x01, 0x02, 0x04, 0x02};// ~
* Strobes the Enable control line to trigger the lcd to process the
* transmitted instruction.
void lcd_strobe_enable(void) {
output_high(GLCD_E);
delay_us (3);
output_low(GLCD_E);
delay_us (3);
* Waits for the busy flag to clear, which should take
* around the maximum time for an instruction to complete.
* Note, LCD operation is kind of sensitive to this configuration. If the delay
* is too fast, the LCD will miss some pixels when it is really put through
* a stress test. This delay time seems to work great.
void lcd_wait_busy(void) {
delay_us(3);
* Writes a command and data raw instruction to the LCD.
* @param command The 4-bit instruction code.
* @param data The 8-bit paramater/data to the specified instruction.
void lcd_write_command(int8 command, int8 data) {
/* Wait for the busy flag to clear */
lcd_wait_busy();
/* Set RW low, RS high, CS low to write the instruction command */
output_low(GLCD_RW);
output_high(GLCD_RS);
output_low(GLCD_CS);
output_d(command);
delay_us (3);
lcd_strobe_enable();
delay_us (3);
/* Set RW low, RS low to write the instruction data */
output_low(GLCD_RS);
output_d(data);
delay_us (3);
delay_us (3);
* Moves the LCD cursor to the specified coordinates.
* @param x The new x coordinante of the cursor.
* @param y The new y coordinante of the cursor.
void lcd_graphics_move(int8 x, int8 y) {
int16 pos;
int8 LA, UA;
/* Calculate the raw address in terms of bytes on the screen */
pos = (_mul(y, LCD_WIDTH)+x)/8;
LA = make8(pos, 0);
UA = make8(pos, 1);
/* Move the cursor to the new address */
lcd_write_command(0x0A, LA);
lcd_write_command(0x0B, UA);
// Purpose: Turn a pixel on a graphic LCD on or off
// Inputs: x - the x coordinate of the pixel
// y - the y coordinate of the pixel
// color - ON or OFF
// Output: 1 if coordinate out of range, 0 if in range
void glcd_pixel(int8 x, int8 y, short color)
int16 pos;
lcd_graphics_move(x, y);
/* Since lcd_graphics_move() moves the cursor to a particular
* byte, not bit, we need the relative distance to the specified
* bit we are going to set/clear. */
pos = x%8;
if (color == ON)
lcd_write_command(0x0F, pos);
lcd_write_command(0x0E, pos);
// Purpose: Draw a line on a graphic LCD using Bresenham's
// line drawing algorithm
// Inputs: (x1, y1) - the start coordinate
// (x2, y2) - the end coordinate
// Dependencies: glcd_pixel()
void glcd_line(int8 x1, int8 y1, int8 x2, int8 y2, short color)
signed int8 x, y, addx, addy, dx, dy;
signed long P;
int8 i;
dx = abs((signed int8)(x2 - x1));
dy = abs((signed int8)(y2 - y1));
x = x1;
y = y1;
if(x1 > x2)
addx = -1;
addx = 1;
if(y1 > y2)
addy = -1;
addy = 1;
if(dx >= dy)
P = 2*dy - dx;
for(i=0; i<=dx; ++i)
glcd_pixel(x, y, color);
if(P < 0)
P += 2*dy;
x += addx;
P += 2*dy - 2*dx;
x += addx;
y += addy;
P = 2*dx - dy;
for(i=0; i<=dy; ++i)
if(P < 0)
P += 2*dx;
y += addy;
P += 2*dx - 2*dy;
x += addx;
y += addy;
// Purpose: Draw a rectangle on a graphic LCD
// fill - YES or NO
// Dependencies: glcd_pixel(), glcd_line()
void glcd_rect(int8 x1, int8 y1, int8 x2, int8 y2, short fill, short color)
if(fill)
int8 y, ymax; // Find the y min and max
if(y1 < y2)
y = y1;
ymax = y2;
y = y2;
ymax = y1;
for(; y<=ymax; ++y) // Draw lines to fill the rectangle
glcd_line(x1, y, x2, y, color);
glcd_line(x1, y1, x2, y1, color); // Draw the 4 sides
glcd_line(x1, y2, x2, y2, color);
glcd_line(x1, y1, x1, y2, color);
glcd_line(x2, y1, x2, y2, color);
// Purpose: Draw a bar (wide line) on a graphic LCD
// width - The number of pixels wide
void glcd_bar(int8 x1, int8 y1, int8 x2, int8 y2, int8 width, short color)
signed int8 x, y, addx, addy, j;
signed long P, dx, dy, c1, c2;
int8 i;
x = x1;
y = y1;
c1 = -dx*x1 - dy*y1;
c2 = -dx*x2 - dy*y2;
if(x1 > x2)
addx = -1;
c1 = -dx*x2 - dy*y2;
c2 = -dx*x1 - dy*y1;
addx = 1;
if(y1 > y2)
addy = -1;
addy = 1;
if(dx >= dy)
P = 2*dy - dx;
for(j=-(width/2); j<width/2+width%2; ++j)
if(dx*x+dy*(y+j)+c1 >= 0 && dx*x+dy*(y+j)+c2 <=0)
glcd_pixel(x, y+j, color);
if(P < 0)
P += 2*dy;
x += addx;
P += 2*dy - 2*dx;
x += addx;
y += addy;
P = 2*dx - dy;
if(P < 0)
P += 2*dx;
y += addy;
P += 2*dx - 2*dy;
x += addx;
y += addy;
glcd_pixel(x+j, y, color);
// Purpose: Draw a circle on a graphic LCD
// Inputs: (x,y) - the center of the circle
// radius - the radius of the circle
// fill - YES or NO
void glcd_circle(int8 x, int8 y, int8 radius, short fill, short color)
signed int8 a, b, P;
a = 0;
b = radius;
P = 1 - radius;
do
if(fill)
glcd_line(x-a, y+b, x+a, y+b, color);
glcd_line(x-a, y-b, x+a, y-b, color);
glcd_line(x-b, y+a, x+b, y+a, color);
glcd_line(x-b, y-a, x+b, y-a, color);
glcd_pixel(a+x, b+y, color);
glcd_pixel(b+x, a+y, color);
glcd_pixel(x-a, b+y, color);
glcd_pixel(x-b, a+y, color);
glcd_pixel(b+x, y-a, color);
glcd_pixel(a+x, y-b, color);
glcd_pixel(x-a, y-b, color);
glcd_pixel(x-b, y-a, color);
if(P < 0)
P+= 3 + 2*a++;
P+= 5 + 2*(a++ - b--);
} while(a <= b);
// Purpose: Write text on a graphic LCD
// Inputs: (x,y) - The upper left coordinate of the first letter
// textptr - A pointer to an array of text to display
// size - The size of the text: 1 = 5x7, 2 = 10x14, ...
void glcd_text57(int8 x, int8 y, char* textptr, int8 size, short color)
int8 i, j, k, l, m; // Loop counters
int8 pixelData[5]; // Stores character data
for(i=0; textptr[i] != '\0'; ++i, ++x) // Loop through the passed string
if(textptr[i] < 'S') // Checks if the letter is in the first text array
memcpy(pixelData, TEXT[textptr[i]-' '], 5);
else if(textptr[i] <= '~') // Check if the letter is in the second array
memcpy(pixelData, TEXT2[textptr[i]-'S'], 5);
memset(pixelData, ' ', 5); // Default to space
if(x+5*size >= LCD_WIDTH) // Performs character wrapping
x = 0; // Set x at far left position
y += 8*size + 1; // Set y at next position down
for(j=0; j<5; ++j, x+=size) // Loop through character byte data
for(k=0; k<8*size; ++k) // Loop through the vertical pixels
if(bit_test(pixelData[j], k)) // Check if the pixel should be set
for(l=0; l<size; ++l) // The next two loops change the
{ // character's size
for(m=0; m<size; ++m)
glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
glcd_pixel(x+m, y+k*size+l, 0); // Clears the pixel
* Draws a byte to the LCD at the current LCD's cursor location.
* @param data The byte to draw. The pixels are drawn MSB to LSB.
void lcd_graphics_draw_byte(int8 data) {
lcd_write_command(0x0C, data);
* Plots a byte at the specified coordinates.
* @param x The x coordinante of the byte to be drawn.
* @param y The y coordinante of the byte to be drawn.
void lcd_graphics_plot_byte(int8 x, int8 y, int8 data) {
lcd_graphics_draw_byte(data);
// Purpose: Fill the LCD screen with the passed in color.
// Works much faster than drawing a rectangle to fill the screen.
// Inputs: ON - turn all the pixels on
// OFF - turn all the pixels off
// Dependencies: glcd_writeByte()
void glcd_fillScreen(short mode)
long i;
/* Move cursor to home (top left corner) */
lcd_graphics_move(0, 0);
/* Draw empty bytes to ocucpy the entire screen */
for (i = 0; i < ((LCD_WIDTH*LCD_HEIGHT)/8); i++)
if (mode == OFF)
lcd_graphics_draw_byte(PIXEL_OFF);
lcd_graphics_draw_byte(PIXEL_ON);
// Purpose: Reads a byte of data from the specified chip
// Ouputs: A byte of data read from the chip
int8 glcd_readByte(int8 chip)
int8 data; // Stores the data read from the LCD
lcd_write_command(0x0D, 0x00);
output_high(GLCD_RW); // Set for reading
input_d(); // Set port d to input
output_high(GLCD_E); // Pulse the enable pin
delay_us(2);
output_low(GLCD_E);
delay_us(2);
delay_us(2);
output_low(GLCD_E);
delay_us(2);
data = input_d(); // Get the data from the display's output register
output_low(GLCD_CS); // Reset the chip select lines
return data; // Return the read data
// Purpose: Initialize a graphic LCD. This must be called before any
// other glcd function is used.
// Inputs: The initialization mode
// OFF - Turns character mode ON
// ON - Turns graphic mode ON
// Date: 5/28/2003
void glcd_init(short mode)
// Initialze some pins
output_low(GLCD_RST);
output_low(GLCD_E);
output_high(GLCD_CS);
output_d(0x0);
delay_ms(1);
output_high(GLCD_RST);
delay_ms(1);
if(mode == ON)
lcd_write_command(0x00, 0x32);
lcd_write_command(0x01, 0x77);
lcd_write_command(0x00, 0x3C);
lcd_write_command(0x01, 0x97);
lcd_write_command(0x02, 19);
lcd_write_command(0x03, 100);
lcd_write_command(0x04, 0x07);
lcd_write_command(0x08, 0x00);
lcd_write_command(0x09, 0x00);
lcd_write_command(0x0A, 0x00);
lcd_write_command(0x0B, 0x00);
glcd_fillScreen(OFF); // Clear the display
void glcd_blank(short mode) {
if(mode == ON) {
output_high(GLCD_ON); // Turn the display on
output_low(GLCD_ON); // Turn the display off
// glcd_pixel8(x,y,px8) sets or clears 8 pixels in line at x,y
void glcd_pixel8(int8 x, int8 y, int8 pixel8) {
lcd_graphics_move(x+1,y);
lcd_write_command(0x0c, pixel8);
//glcd_image8 (*Pic, x, y, size_x, size_y)
void glcd_image8(int8 *pic_px, int8 x, int8 y,
int8 size_x, int8 size_y) {
int8 px_y;
int8 px_x;
int8 px=0;
for(px_y=y; px_y<(y+size_y); px_y++) {
for(px_x=x; px_x<(x+size_x); px_x+=8) {
glcd_pixel8(px_x, px_y, *(pic_px+px));
px+=1;
void glcd_text8x8(char *Pix, int8 line) {
int8 i; // Loop counters
char pixelData[8];
for(i=0; i<20; ++i) // Loop through the passed string
// if(textptr[i] < 'S') // Checks if the letter is in the first text array
// memcpy(pixelData, TEXT[textptr[i]-' '], 5);
// else if(textptr[i] <= '~') // Check if the letter is in the second array
// memcpy(pixelData, TEXT2[textptr[i]-'S'], 5);
// else
// memset(pixelData, ' ', 5); // Default to space
if(Pix[i] < '4') // Checks if the letter is in the first text array
memcpy(pixelData, TEXTA[Pix[i]-' '], 8);
else if(Pix[i] < 'H') // Check if the letter is in the second array
memcpy(pixelData, TEXTB[Pix[i]-'4'], 8);
else if(Pix[i] < ('\\')) // Check if the letter is in the second array
memcpy(pixelData, TEXTC[Pix[i]-'H'], 8);
else if(Pix[i] < 'p') // Check if the letter is in the second array
memcpy(pixelData, TEXTD[Pix[i]-'\\'], 8);
else if(Pix[i] <= 0x7F) // Check if the letter is in the second array
memcpy(pixelData, TEXTE[Pix[i]-'p'], 8);
else {
memcpy(pixelData, TEXTA[0], 8); // Default to space
glcd_image8(pixelData, i*8, line*10, 8, 8);
void move_char(int8 x, int8 y) {
int16 pos;
int8 LA, UA;
/* Calculate the raw address in terms of characters on the screen */
pos = (_mul(y, 20)+x);
LA = make8(pos, 0);
UA = make8(pos, 1);
void glcd_char(int8 x, int8 y, char* textptr) {
int8 i;
move_char(x, y);
for(i=0; i<20; i++) {
lcd_write_command(0x0c, textptr[i]);
void char_fillScreen(short mode) {
long i;
move_char(0, 0);
/* Draw blank or filled chars to ocucpy the entire screen */
for (i = 0; i < 160; i++)
if (mode == OFF)
lcd_write_command(0x0c, 0x20);
lcd_write_command(0x0c, 0xFF);
