gremi
Joined: 11 Mar 2008 Posts: 20 Location: Toulouse, France
| Compilation error |
Posted: Wed Mar 12, 2008 2:32 am |
Hello everybody,
first of all sorry for my bad english (I'm french) ;)
I'm trying to write on a sd card with a 18F4620, using FAT.
I want to use the ccs driver, but I've an error while I compile :
| Code: | #include <18F4620.h>
#fuses XT, NOWDT, NOPROTECT
#use delay(clock = 4000000)
#use rs232(baud=38400, xmit=PIN_C6,rcv=PIN_C7)
#include<stdio.h>
#include<string.h>
#include<mmcsd.c>
#include<fat.c>
set_tris_b(0);
output_high(PIN_B1);
delay_ms(200);
output_low(PIN_B1);
delay_ms(200);
This is the begining, but at compilation I've got this message :
Executing: "C:\Program Files\PICC\Ccsc.exe" "main.c" +FH +DF +LN +T -A +M +Z +Y=9 +EA
>>> Warning 203 "main.c" Line 18(1,1): Condition always TRUE
Memory usage: ROM=0% RAM=14% - 14%
0 Errors, 1 Warnings.
Executing: "C:\Program Files\PICC\Ccsc.exe" "fat.c" +FH +DF +LN +T -A +M +Z +Y=9 +EA
*** Error 128 "D:\guillot\ecriture\string.h" Line 34(1,2): A #DEVICE required before this line
1 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Wed Mar 12 09:19:36 2008
But the #device PIC18F4620 is already in the 18F4620.h
And If I add #device PIC18F4620 in string.h, I've a message "#device already configured...."
I think it's a newbie problem but I cant resolve it... can you help me?
Thanks ... |
Posted: Wed Mar 12, 2008 3:24 am |
Are you compiling from MPLAB?.
It actually looks as if you are compiling your main.c, with all it's required includes OK, and then separately compiling fat.c, which doesn't have a processor definition, and includes string.h itself. The error is on this second compilation.
If you are working from MPLAB, then this is because fat.c, (because it has a .c extension), has 'by default' got flagged as a source file, rather than an 'header' file. In the 'files' window, you need to move the file from the 'source files' branch, to the 'header fles' branch.
gremi
Posted: Wed Mar 12, 2008 3:30 am |
Yes, I'm compiling from MPLAB (I Use MPLAB ICD2) and you're right, fat.c is in the source file section, not in hearders.
But if I try to add fat.c as a header, MPLAB puts if automatically in the source file section.
Do I have to rename fat.c to fat.h ???? |
gremi
Posted: Wed Mar 12, 2008 4:47 am |
I renamed fat.c to fat.h and it seems to work.
I've got an other problem, trying to write on a file :
FILE fichier;
fat_init();
fatopen("toto", "w", &fichier);
fatputc("mytext", &fichier);
fatclose(&fichier);
And ccs returns me an error message :
*** Error 90 "main.c" Line 23(19,20): Attempt to create a pointer to a constant
I've looked to the documentation, and I've seen that :
| Quote: | | Constant tables are implemented as functions. Pointers cannot be created to functions. For example CHAR CONST MSG[9]={"HI THERE"}; is permitted, however you cannot use &MSG. You can only reference MSG with subscripts such as MSG[i] and in some function calls such as Printf and STRCPY. |
But i don't undernstant where the problem is ... can you help me???
Thanks. |
Posted: Wed Mar 12, 2008 6:02 am |
A search in the forum will find a lot about this. Basically, you have to remember that the PIC, has a somewhat 'odd' architecture, with the ROM memory, separate from the RAM. This means that objects in ROM, are in a different 'address space', to those in RAM, so if you declare a simple string 'constant', like "Hello", which in a normal processor, can be addressed using a pointer, in the PIC, it can't (some other compilers, have bodges to work round this).
So, you either need to copy the string constants into RAM, before using
them, or declare them as RAM variables. So:
FILE fichier;
char temp_buff[10];
char wcmd[]="w";
fat_init();
strcpy(temp_buff,"toto");
fatopen(temp_buff, wcmd,&fichier);
This shows both routes to put the values in RAM.
There is a 'work around' for this, for constants, declared using the #ROM declaration, on the recent compilers.
